Old 02-03-2009, 03:47 PM
Ferman Ferman is offline
Rep: 10 Posts: 19
aft hull chine for sailboat afecting performance
Hi,
I have seen lately some inovations in sailing desingns that make me wonder if they really work in a beter performance of sailboats like the aft hull chine or the doble ruder or doble dagger board with swinging kell, i realize that this work in performance but specially the aft chine does it really make the diference.
Old 02-03-2009, 05:07 PM
Rep: 696 Posts: 1,232
It can make a difference on some, but not all boats. We usually see that feature on boats that are capable of sailing above standard hull speed. The hard chines aft help keep the boat from squatting so badly at or near transition speeds. Some of these boats can achieve a mushy planing speed.
Twin rudders and twin daggers are canted outward to make the foils more nearly vertical when the boat is heeled. All these nifty design features need to be able to work in concert with one another. None of those features should be added to an existing boat except on the advice of a knowledgeable design person.
Old 02-03-2009, 05:29 PM
Eric Sponberg's Avatar
Rep: 2447 Posts: 1,376
These features aren't new--they've been around for decades. Yes, they do work. Chines help keep a boat on plane a little longer and maintain speed better than if it did not have chines. The boat must be quite light in order to achieve planing speeds for these to work. If the boat can't plane to begin with, the chines might not help that much. Hulls with chines have more wetted surface than boats without chines, so if the boat is always sailing in displacement mode, it might be slower than its non-chine counterpart, particularly in light air.
Double-rudders are a no-brainer--the leeward rudder is left down while the windward rudder is withdrawn. Such boats have built-in redundancy--break one rudder and you have another right handy. The downside is extra cost to have two rudders instead of one.
Swinging keels with double-daggerboards--they generally go together because a boat with a swinging keel has poor windward ability. It loses lateral plane when the keel is canted. The daggerboards make up for that lost lateral plane. Such boats are harder to control, they are more expensive to build, and the keels and daggerboards take up interior space, all of which is why you see them on racing boats but not on cruising boats.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 02-04-2009, 01:30 AM
alberto88 alberto88 is offline
Rep: 10 Posts: 17
aft chine is work when planing, but when not plane then chine is slower sometimes, especially in the light.
Fashion more than function; the quickest sportboats around many still not have chine.
Old 02-04-2009, 02:30 PM
Steam Flyer's Avatar
Steam Flyer Steam Flyer is offline
Rep: 10 Posts: 31
Heck yeah.
Anybody remember the Force 5, a competitor to the Laser (and in the opinion of many, a better design)?
True, but it's a complex trade-off between wetted surface area and increased form stability at low heeling angles.
More righting moment = more horsepower = more speed. If the designer is clever enough to place the chine such that the boat isn't dragging a corner thru the water at normal sailing angles, yet gains a significantly higher metacenter, the boat can definitely be faster once out of "light air" mode. And a partial chine aft (such as the Force 5 had, and many skiffs have, and some sportboats are starting to wear) doesn't generate the awful helm forces that a full-length chine does.
Aft chines.... a fad, but with some reasoning behind it
FB- Doug
hard chine sailboat design 45-55ft saltflower Boat Design 1 03-16-2008 01:39 PM
Aft weight reduction and performance Art_H Powerboats 6 01-20-2008 12:25 PM
Wine glass stern and small aft-cabin sailboat xarax Boat Design 2 07-12-2007 08:51 PM
what about hard chine aft jelfiser Boat Design 8 07-23-2006 09:56 PM
Aft salon in a sailboat Balboa Boat Design 4 12-21-2002 09:01 AM
