| Adding sail and maintaining the CE balance I have a 46'-9" ketch sailboat that I would like to improve the sail area to increase performance in light airs. If I were to add 2.0' to the foot of the head sail via bowsprit and 4.0' to the foot of the mizzen, would I be maintaining the balance of the CE to center of lateral plane. I am unable to change the main. Additionally, would changing from a 130% genoa to a 150% change the helm balance, because I notice architects only use 100% of the foretriangle in calculating the CE. The current sail area is quite low at about 800 to 850 sqr ft. Thanks for your help. |
| Low aspect may not be the way Gday The potential fixes you have mentioned seem reasonably expensive. The rigging of a bowsprit and new forestay, furler section and then increasing the mizzen boom length and buying a new mizzen sounds pretty pricey. My prediction is that it would not do much for your upwind light air performance. This is because you are decreasing the aspect ratio of the rig. I would recommend you do the opposite. You can increase the aspect ratio (in a way) of the mainsail you have by increasing the roach and going fully battened. Look at Steve Dashew's Ocean cruising encyclopeadia a few examples of this. If you could put in a triatic stay or similar for the main mast you may be able to dramatically increase mainsail area. A roached planform is more efficient and a new main may prove to be a better investment than the other changes mooted. cheers Phil |
| No changes are needed because this is a new build. I was already planning on fully battened main with roach. |
| Duplicate thread, more discussion here . . . Adding sail & maintaining the CE balance! |
| OK.........take a deep breath (adding sail to houseboat?) | GOTTABSOMEWHERE | Boat Design | 23 | 07-13-2009 11:44 AM |
| Maintaining a wet edge while rolling and tipping the deck | GWB | Fiberglass and Composite Boat Building | 7 | 04-06-2008 10:06 PM |
| Maintaining Structural integrity | James Francis | Fiberglass and Composite Boat Building | 2 | 07-20-2006 04:57 PM |
| New Balance Rig sail? | Wellydeckhand | Sailboats | 3 | 04-29-2006 01:44 AM |
| Sail design and boat balance | Archive | Sailboats | 1 | 06-21-2001 02:04 PM |
