| Adding a bulb to keel Hi, I'm considering adding a bulb of around 200 lbs. to the keel of my Laser 28 racer/cruiser. The boat displaces about 4250 lbs of which 1500 is in the keel. Draft is 5 feet. Boat is high performance with SA/D ratio of around 26.5. The boat was designed to race with a crew of 6 but I often sail single handed or with a small crew, therefore the boat is quite tender and I need to reef early. Does anyone have experience of adding a bulb? Will a bulb of approx. 15% of the keel weight stiffen the boat up considerably? Thanks |
| Can't you experiment?? Fit different weights on your keel and sail with it, till you find the one you feel comfortable with and then fix it permanent. About the amount you propose: 15% of keel weight, almost 5% of total weight. I would say, yes, you start changing stability considerable.
__________________ Dutch Peter “The opinion of the majority is not necessarily correct” – Yi Qing Cui |
| Be sure to check if the keel attachment (keel bolts, floors etc.) can take the extra load. And also remember that when you do sail with a full crew, the loads on the rigging will increase too. |
| Why put a bulb on the keel? With such a small amout of lead, you would be better off lengthening the keel itself with this amount of lead. You get the same added righting moment, with a little less induced drag, and you do it without the the drag associated with a bulb. A bulb needs carefull design if you are to gain righting moment without losing speed. |
For what the drag is concerned, I 'm not to experienced with that, but it seams to me that lenghtning the keel will create more area, i.e. more resistence, then when fitting a bulb. When the bulb is resembling a drop of water or a torpedo (same??) it shouldn't be such a big problem, should it? And fitting the bulb is easier!
| Dutch Peter. I don't know the dimensions of the keel, so I may be talking out of place. Quote:
Don't get me wrong. I think bulbs are wonderfull. If you have a draft limitation they are the best way to go, but without a draft limitation, you get less resistance for the same righting moment, just by lengthening the keel. 200 lb = 0.28 ft^3 = very small volume. I may be wrong. |
If the area is just marginal effecting the amount of drag, isn't the keel-bulb connection having the same marginal effect. Resulting in a + for area and a - on connection radius thus, resulting in 0 on extra drag compaired to lenghtning? Told you, it's not my area and I'm sailing for the "piece and quiet" on the water, so, not interested in .5 knt extra.
| I wonder why I didn't think of lengthening the keel... Making the keel deeper will add area and (let's not forget this) increase the aspect ratio, making the keel more efficient as the coefficient of lift is increased. In other words, you'll be able to point higher. Off the wind, however, you'll go a bit slower. The bulb will also increase the coefficient of lift, but not as much. |
So what is the best option? Or is the easiest option the best option, as without modeling or testing the arrangements it can not be determined?!
| The best option, from a hydrodynamic point of view is a deeper keel. (If, a deeper keel is no problem.) The "proportionately less induced drag of a deeper keel / greater effective span of the bulb end effect" tradeoff must go to the deeper keel. The bulb will not maintain streamlines unless designed properly. You will get a lot more drag. It is not worth the trouble. Anyway, you will get a better righting moment in the deeper keel. The bulb distributes its weight sideways as well as down since it has a circular section. The deeper keel option, since it is a thin section distributes its weight deeper than the bulb, and hence it's center of gravity is lower. |
Apart from that, I agree with Dionysis. From a hydrodynamical point of view, the extended keel is best, because it will have a better lift/drag ratio. So if there's no restrictions on draft, this is the best choice. |
p.s. I read recently on another board that Mars was difficult to work with. Any comment? |
You could remove the keel (and as you may have to replace the keel bolts with new, larger ones this has to be done anyway), drill holes in the bottom, cut threads and bolt on the extension from its bottom. In other words exactly as you would do it, if you were adding a bulb. |
| Laser28, Adding a bulb is simple, and it will help with your stability. The added drag will be overcome by the ability to carry more power in the sails. The Laser 28 is a fine boat, and will benefit from the modification. I would attatch the bulb in two halves, split longitudonally. Make a template of the tip section were the bulb will go. Shape the inside face of the halves so they match the tip section, and thru bolt them together, then do any nesc. fairing with thickend epoxy. Happy sailing. |
| Go with lengthening keel, not bulb. The added drag of the increased surface will be more than overcome by the increase in aspect ratio (sailplanes have long slender wings for good reason). Just take the leading edge, the trailing edge, and a few lines along the span and extrapolate them, then fair the intersections of those lines with horizontal (chordwise) planes to get the same airfoil shape. |
| Cheap And Simple Hi-Tech Keel? | Wynand N | Boat Design | 9 | 05-24-2005 08:55 PM |
| Keel, bulb and rudder design | ivansalasj | Sailboats | 5 | 02-06-2005 12:42 PM |
| keel bulb design - help | garofaloj | Sailboats | 17 | 01-14-2005 12:36 PM |
| Adding A Keel | AAAAPPPP | Powerboats | 1 | 05-26-2004 01:47 AM |
