Old 11-15-2004, 12:27 AM
airturb airturb is offline
Rep: 10 Posts: 13
Acceptable deflections in masts
HI ALL AGAIN
Once again, another design question...what would be the allowable deflection of a mast to consider it "successful"? I'm not concerned with the stresses involved for a particular deflection, but rather the interaction that this deflection will have with the sail.
Cheers.
Old 11-15-2004, 05:24 AM
249
But it's a question without an answer, isn't it??
It depends on the mainsail. A rigid main will need less mast bend, a dacron main will need more. Then there's the effect of the way that the class or rule measures SA, and whether the luff curve is measured area or not. Plus there must be many other details; the amount of mast bend depends on whether it is a masthead rig, a runnerless rig, or a runner rig. If you have too much mast bend in a runnerless rig on a sizable yacht, the forestay tension drops away too much so the jib shape is impaired.
Carbon Fibre Masts Wynand N Boat Design 64 05-05-2008 01:26 AM
Finn or Contender masts... Sean Herron Boat Design 2 03-20-2005 03:00 AM
Wooden masts & mast steps yachtadina Wooden Boat Building and Restoration 3 12-26-2004 08:06 PM
Steel Lattice Masts MikeJohns Boat Design 8 08-11-2004 09:59 PM
Aluminum masts: mechanical properties Gades Boat Design 3 09-09-2002 10:07 PM
