Old 02-15-2005, 02:36 AM
BriceL BriceL is offline
~ 6.5m design for amateur construction
Hello,
I am looking for different options in order to built a 6-7 m boat.
Most probably a sport boat, but It would be nice to have something that goes well in choppy seas (melbourne weather).
The options I saw are Thompson 650, some mini designs (also probably a bit expensive)
The max budget would be around 20,000 AUD...
ideas anyone ?
Old 02-15-2005, 03:17 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Didi 26 is longer than your rec. (8 meters), but very light, approx 1000kg with 400kg lead bulb. I estimate a complete kit for building the boat (hull, deck, interior, epoxy) costs 8000USD while a complete rig may cost 4000USD.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 02-15-2005, 03:38 AM
mojounwin mojounwin is offline
Rep: 10 Posts: 58
Colson
Try a Barry Colson design,
He's a Kiwi designer that is now based on Bribe Island in Queensland.
He should be able to customise a design to suit your needs for cheaper then most designers would sell you a stock plan set.
his website is
www.colsonyachtdesign.com
Best of luck
Mike
Old 02-15-2005, 05:35 PM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
Perhaps I can help. I have a 7.5m sportsboat design, which may interest you. Built as an E-Glass foam/balsa using CNC cut jigs and plugs, it might be usefull in its current form but is more expensive than your budget allows. One has been home built here in queensland.
Conversely, adapting it to a smaller version and altering some of the material specifications could bring it into your budget range. There is a deck mould available for the 7.5m which could be used without too much modification.
Send me your email address I will forward some photos (too big to post here).
Brett
