Old 03-18-2010, 08:16 PM
ScottK ScottK is offline
Landlubber
Rep: 10 Posts: 9
40' Shallow Draft Boats?
If a person is looking for a sailboat around 40' in length with a draft that is under 4' when loaded, with a single fixed keel, are the only two choices the 35' Shannon Shoalsailer http://www.shannonyachts.com/sail35.html or a 37' Bruce Roberts Spray http://www.bruceroberts.com/public/HTML/S370.htm ? Or does one have to install a Scheel keel on an existing design?
Ideally I would want something around 40'+- in length, with a steel hull. Something that could comfortably take a couple of people, and if needed a couple of kids, around the world.
ScottK
Old 03-18-2010, 09:31 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
There may be a few other options, but I'd say the essence of the problem is simply that the physics of the situation just don't work out too well for shallow fixed keels on large boats. Good sailing performance in a typical fixed-keel monohull calls for a lot of ballast, low down.
Of course, fixed keel isn't the only way to go, and while you may have your heart set on metal, I wouldn't be so restrictive as to insist on steel. How about something like an Ovni ( http://www.northseamaritime.com/Page/ALUo395.htm ) ? Do you have anything against centreboards? Multihulls?
Fleshing out your requirements in more detail will of course be a necessary step in the boat hunting process, but at this stage, dreaming and investigating is what it's all about....
Old 03-18-2010, 09:45 PM
Landlubber
Rep: 10 Posts: 9
Thanks Matt. I understand the short-comings of long shallow fixed keel sailing yachts, and the advantages that multihulls can offer. I'm still set on a steel monohull design though.
I am a bit concerned about what would happen to the hull of a boat that uses a centerboard if it is frozen in the ice. Even freezing in a hull with twin keels would concern me. Freezing water (Ice) can easily crush or expand steel to it's breaking point. And yes, I know, I 'm supposed to be sailing to warmer climates, right?!
Old 03-18-2010, 09:54 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
I recall Ted Hood designed centerboarders that performed well. Craig Walters, too. And what's the British firm that makes such boats, Southerly?
I agree one should check out Ovni.
Old 03-19-2010, 02:48 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,026
Scott, you might want to have a look at some Joe Adams or Graeme Radford designs, I think they may have had some shoal draft steel yachts in that range, All the best from Jeff.
Old 03-19-2010, 05:15 AM
Rep: 1493 Posts: 7,447
There are alot of centerboard, leeboard, bilge keels and keel/centerboard designs. I would say at least in the hundreds.
Old 03-19-2010, 05:45 AM
Milan Milan is offline
Rep: 279 Posts: 320
If you like steel and you need shallow draft, you should look at the Dutch designs. (The Netherlands is a steel boats heaven and has a lot of shallow waters).
Yacht Designer Dick Koopmans Sr. for example, sailed tens of thousands of miles in high latitudes in his centre boarders.
http://www.dickzaalyachtdesign.nl/ya...center%20board
http://www.dickkoopmans.nl/uk/index.htm
http://www.nbja.org/yachtdesigners/index.html
Maybe Yago 36
http://www.yago-project.com/content/...77/59/lang,en/
Old 03-20-2010, 05:31 AM
Rep: 756 Posts: 3,328
A rather simple rule of thumb is the depth should be 1/7 the LWL on a long keeled cruising boat.
The long keel will take the ground , and with 4x4's with pads can be made to stand easily while aground.
The simpler steering requirements and better tracking of the long keel makes self sterring easier and auto pilot electrical loads far lower.
Reefing can be later as being overpowered does not make the boat wonkey .
FF
Old 03-21-2010, 04:28 PM
david@boatsmith david@boatsmith is offline
Rep: 50 Posts: 85
Tom Colvin designed many shallow draft steel sailboats, most with boards but some with keels. David
http://www.thomasecolvin.com/index.html
Boatsmith Inc
We Build Your Dreams
(561) 744-0855
www.boatsmithfl.com
Old 03-26-2010, 10:56 PM
Landlubber
Rep: 10 Posts: 9
Thanks all. I also found some interesting ones at Tanton Yachts.
Scott
Old 03-29-2010, 07:27 AM
ImaginaryNumber ImaginaryNumber is offline
Rep: 148 Posts: 127
Alcyone
You might also consider Max Gunning's Alcyone series. They are steel, flat-bottom, less than 3' draft, internal ballast, kick-up rudder and centerboard, mast in tabernacle. Some are center cockpit, some aft cockpit.
http://www.alcyone-archive.org/UK.html > Max Gunning > correspondence > links in left column
Old 04-04-2010, 08:23 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
shallow 4' draft
See Parker Marine Designs (Ruell Parker)<http://www.parker-marine.com>. They have a wonderful design catalog of shallow draft boats to 60 feet. There are many many alternatives out there, you just have to decide how much or how little displacement per person you can tolerate. I don't like Roberts SPRAYs much myself, he's a salesman, not a particularly good designer, though many people have taken them across any piece of water you can name and I've often run into them cruising in Mexico, Canada and Alaska.
I sailed a different modified SPRAY type of my own design for a couple of decades at 7-9 tons per person and was very comfy with our 5' draft and vast supplies of food and water. See the SPRAY thread and ANTIQUE TECH for more.
Seeking shallow draft boat with family comfort gregwilby Sailboats 5 05-06-2009 06:34 AM
design on shallow draft craft. jtmboat Boat Design 1 03-05-2009 07:32 AM
shallow draft propulsion for catamran ferry lausl Surface Drives 4 12-25-2007 11:16 PM
Shallow Draft Boat depinux Boat Design 1 06-03-2007 01:12 PM
Shallow draft rudder foil-wild Doug Lord Sailboats 0 08-28-2005 04:38 PM
