#46
| Hi Doug, have you got a higher res image of the yacht? |
#47
(I would save a ton on carbon)Quote:
thank you again, very helpful stuff..........
__________________ Samuel Schneider http://sr-71monofoilerproject.blogspot.com/ |
#48
thanks for the input and Veloceraptor links...
#49
| Paint I used the Imron because of faster cure time and the eventual hardness it reaches. Imron doesn't use reducer like most paints for spray application - just their own hardener. Some folks I really respect at Phil's Foils swear by it for finish paint. Imron is pretty evil in terms of the chemical content. You've got to have a positive pressure air system, paint booth and a good mask as well as 100% skin coverage. I didn't go near it during painting - a lot of automotive painters won't use it, even though it produces unquestionably good results. Eric painted the boat in his paint booth using a good spray gun and compressor. I'm very happy with the finish. No detectable orange peel and no runs. Fairing compound? West System. I kind of have a bad memory of this as you put it on and remove 99% of it sanding, but you have to do it. After fairing and sanding we used a fair amount of Awlgrip primer to build it up again for wet sanding at 220, then 400. There were two colors of Awlgrip primer used - first grey and then white to help gauge final sanding. Almost all of the white was sanded off, and it provided a very visible indication of surface problems - you could see sanding scratches easily because of the white on grey. After sanding there was a final finishing filler pass which was used to fill any remaining problems, re-sanding at 600 wet and then the final Imron. Eric is really good at this - I learned a lot. Eric spent a couple weeks interning with Larry Tuttle of Waterrat fame this year learning about finishing technique.If you don't know who Larry is, ask a 505 guy. |
#50
#51
| Even after the 400 wet pass sanding down the white primer to mostly grey, it was very visually apparent when there were sanding scratches and voids. The primer did not fill everything in completely, so a very fine filler was ghosted over these areas, which were then brought up to surface level. This filler was something I had never seen before - Eric indicated that high end automotive painters and perfectionists like Larry did this to assure their finished surfaces were fair and flat. From the results it really works. The final 600 wet rendered a very nice surface for the Imron, and probably had a lot to do with how well the paint spread and settled flat. Although it is paint on epoxy/glass over wood it looks like a Mercedes car quality finish. I'll ask Eric what exactly the product was at this stage. It was in a squeeze tube and was a very fine paste filler. We used a soft plastic scraper for application. -- Bill |
#52
| More drarings so, I spent another Sunday on the computer, I cant wait to start getting my hands dirty. today it was all about mold design. Got some frame sheets done for my deck mold and pretty far into my hull mold (just have to draw a stucture for my frames to go on). Heres the pics....... ( I cant believe I got all those frames on to one 4x8 sheet)
#53
I know this from having a very understanding software guy at the CNC shop 6 years ago who took the time to reconfig my original nest so that it would work when I started to put the thing together. Chris |
#54
| cnc is for cheaters Quote:
I was going to do it the old school way, Kinko's and a saw, (I've seen many boats done this way, Swift solo, half the worlds moths, International Canoes,) they all seem to still get through the water alright I know CnC is more accurate and faster, and now that I think about it probably more cost effective. So on second thought I might have to make some calls tomorrow. If I did go Cnc and had to change the drawings it would not be hard, all the frames are "joined" objects, so I can just drag them around at will, would take about 10 minutes. Just for kicks, what is a good frame spacing? and what kind of file do I need to convert to?Thanks
#55
| The typical cutting tool is 1/2" in diameter minimum for this type of operation. They should be able to accept .dwg, .dxf files for conversion to their machine software with no problem. The trick is making sure that all the curves are joined and that there are no breaks for the cut path. If you send them the file before you show-up with the stock to be cut, you probably will not be there more than 1 hour total. Smallish cabinet shops with full sheet CNC tables will be the most cost effective, with the bigger shops having the fastest feed rate machines. It's really good if you find a shop where the machine operator or the shop owner are boat nuts (of any kind) I've had my best experiences with that type of setup. Also doesn't hurt to supply them with some CAD images of the project as it will tulook when completed. Most of these guys are cutting Melamine laminated particle board all day, so when someone shows-up who is making a carbon flying machine, they will get special attention. The guys who cut my parts have renderings of my boats hanging on the wall next to the control station and a couple of them have dropped by to see how it all is going together. It makes for a fun project for everyone. Chris |
#56
The panels were "wet out" and cured with epoxy before cutting on the CNC table to help prevent edge tearing and save time later during assembly. We only had to wet out the edges after cutting. In your case with the male plug you might want to consider wetting out the inside of the frames just to keep the moisture out of the finished plug. Not that it will be an issue for the first hull, but over time the plug may not be stable if you seal the outside surface and leave the inside to breath and absorb water. This idea may or may not have merit. Just a thought. -- Bill |
#57
| so, talked to a friend who manages a wood shop (the one selling me the MDF and plywood), he doesn't have a Cnc, but has a good friend who has a nice machine in his spindle shop, 4x8 table, so I need to go talk to them when I have my drawings finalized. (yet one more reason to stay focused and get them done) Quote:
thanks for the pointers, keep em comin... ****background info****** I am making a male mold from 3/8'' Mdf, covered with a 1/4'' ply skin, microlight filler, then 9oz glass, more mircrolight, then sprayed with sandable primer. Buff a little then vac bag to it. sound good ![]()
#58
| So many coats of release agent that your head swims three coats ago. It is absolutely astounding how the most tiny of little air dents in the surface will manage to hold your part when you try to make a clean pull. Take the kids out of the room when you pull the first part. Daddy may turn ugly.... ;-) Chris |
#59
#60
As well when talking to the CNC people find out clearly about how they hold down the material. Many use vacuum tables, but if they aren't high tech, make sure you know where they will be clamping/screwing down so you don't put a part where you don't want it ventilated or smooshed. I'd be a little skeptical about vacuum tables as well - you just can't afford to lose registration of your datum once the cutting starts. |
| Foiler Design | tspeer | Sailboats | 1031 | 12-17-2010 02:38 AM |
| 3 legged foiler? | sailing_ks | Boat Design | 1 | 04-12-2007 07:16 PM |
| Foiler cat | tamkvaitis | Multihulls | 6 | 02-04-2006 08:03 PM |
| mono vs multi hull | Robert Harik | Sailboats | 6 | 05-16-2004 05:04 PM |
| Cat or Mono or............................ | Nomad | Option One | 12 | 05-31-2002 08:48 PM |
