  #316
Old 01-30-2009, 08:53 AM
wind_apparent's Avatar
wind_apparent wind_apparent is offline
wind driven speed addict
Rep: 96 Posts: 257
I'm basicly trying to keep this project low key (away from the forums) for the most part......until I have some pictures and video to post of me flying along up in the air and out on the wire. Everyone has seen build pics before. All the really interested people seem to keep track of whats going on through the blog. I get E-mails everyday full of idea's and questions, so thanks to those sailors for their support, Its coming along and will be done when its done.
Sam
Samuel Schneider http://sr-71monofoilerproject.blogspot.com/
  #317
Old 05-22-2009, 07:19 PM
Rep: 96 Posts: 257
After hearing that doug has been banned I am rearing my ugly head again. A lot has happened since I've been around these parts. I have finished the hull plug and just glassed the deck tool as well. Just need to build the foredeck plug and it will be on like Donkeykong. I have a couple questions for all you spray buffs out there:
After all the moulds are built and glassed I want to coat them with Duratec sandable primer as my tool finish. Is this brush or rollable or do I have to shoot it? Are there any issues with humidity (some of these coatings have bonding issues even with low humidity levels). And Do I have to buff it all the way to gloss or would sanding to 400 or 600 do the job? Thanks.
Sam
  #318
Old 05-22-2009, 07:39 PM
yachtyakka yachtyakka is offline
Rep: 25 Posts: 35
I was talking with Paul Mac today at the Onetangi Sports park. I taped a interview where he talks about the foil being the future..
I will post it once its uploaded to youtube.
Did you know that Dan is selling sets of foils?
  #319
Old 05-22-2009, 07:50 PM
Rep: 96 Posts: 257
I would love to see that interview. Who is Dan? is he selling moth foils? where can I see them? (Pricing?). I'm looking for a set of foils (mach 2? Illiet? aardvark? Used?), the new plan is to put a square main foil box in the hull instead of a foil shaped case so that I can switch out foils at will. I plan to start with a moth foil set based on the fact that they are working well on Bruce Gaunt's 16' trapeze foiler in Aus and all the controls have been sorted. Then move onto my own optimized foil set.
  #320
Old 05-23-2009, 04:37 AM
Rep: 25 Posts: 35
Dan Leech, designed the foiling RClass L3 and is now selling sets of Foils for the RClass.
Interview here
http://yachtyakka.co.nz/2009/05/yach...s-may-part-13/
  #321
Old 05-23-2009, 07:04 PM
Rep: 96 Posts: 257
Great stuff.....I don't think that the R foils would work very well on the SR because the numbers don't match up very well. To much lift area (drag) for this projects weight/sail area. I'd rather have a little less lift area than I need(moth) than to much (R). Using the moth foils I might give up a little on early lift off, but higher top speed is an alright trade off I think. I often kick around the idea of building an R mould when I'm done with this frankinstien. I think it would be a great class to introduce to the States. (***Yes I'm crazy ***) Well, I'm off to sand fresh fiberglass.
  #322
Old 03-11-2010, 11:27 PM
Rep: 96 Posts: 257
Haven't been to these parts in a while, but the tools are done and ready to lay up, spent the day looking into vacuum infusion. Really leaning that way.
  #323
Old 03-12-2010, 09:06 AM
Doug Lord's Avatar
Flight Ready
Rep: 838 Posts: 5,123
Are you going to lay up a hull off the hull plug or lay up a mold and then a hull? Good luck!
yes, it is a revolution
---"So (yet) another new world begins."
Andrew Hurst, editor of Seahorse magazine, August,2011
  #324
Old 03-12-2010, 11:44 AM
Rep: 96 Posts: 257
Lay up off the plug for this first one, I know its not ideal, but its the easiest as far as tooling is concerned. Just want to get this first boat up and running, so I can get a feel with whats going on with it. I have plans in the works to build a female clamshell mould next. (to a new design from the same formula)
  #325
Old 03-31-2010, 04:42 PM
Doug Lord's Avatar
Flight Ready
wind, you should see post 1030 here:
http://www.boatdesign.net/forums/sai...-11209-69.html
  #326
Old 09-25-2010, 10:09 PM
Doug Lord's Avatar
Flight Ready
A new monofoiler is born
He did it! Congratulations!
  #327
Old 09-25-2010, 10:23 PM
Doug Lord's Avatar
Flight Ready
I realize it's too late on your current boat but it's been bugging me for a while: I would hope you would be amenable to modifying the rule to allow the LOA to be 4.55m and allowing a potential designer to eliminate the gantry.
The gantry(in my opinion) is a rule induced abberation which is NOT necessary for a successfull foiler design. In fact, there are really good reasons why it should be eliminated:
1) by allowing the hull to be a bit longer the available hull buoyancy is increased so the L/beam ratio can be increased reducing resistance and allowing the boat to achieve takeoff a bit sooner.
2) In my humble opinion, it is somewhat ugly and help creates a "contraption" appearance to some onlookers.
3) When taking off without an F-box(angle of incidence control) a gantry (and transom)drags when the boat is pitched bow up.
4) The ONLY reason for a gantry is to allow the foil footprint to be better on a boat NOT DESIGNED FOR FOILS IN THE FIRST PLACE.
So whataya say,can the rule be amended to allow "gantry-less" designs 4.55m LOA?
I've totally changed my mind on this -at least for small multihull foilers. Are you going to use a gantry, Sam?
  #328
Old 10-18-2010, 12:58 PM
Rep: 96 Posts: 257
Yes, a 50cm gantry. The hull has also been cut down to 3.85m proper, so should be 4.35m with gantry. It was just a little long, so I cut it down some. 10cm off the stern and 5cm off the bow. I am also cutting the beam down from 70cm to 55cm. And adding tramps.
  #329
Old 10-18-2010, 02:30 PM
Rep: 96 Posts: 257
I'm also working on the class rule. I'll post it here soon for input
  #330
Old 10-18-2010, 03:43 PM
Doug Lord's Avatar
Flight Ready
Looking forward to it. Suggestion: allow the same total overall length with or without a gantry. Allow sliding seats-whats the harm? Allow more than two foils-again-whats the harm? Don't restrict beam-maybe just restrict crew movement?
Foiler Design tspeer Sailboats 1031 12-17-2010 02:38 AM
3 legged foiler? sailing_ks Boat Design 1 04-12-2007 07:16 PM
Foiler cat tamkvaitis Multihulls 6 02-04-2006 08:03 PM
mono vs multi hull Robert Harik Sailboats 6 05-16-2004 05:04 PM
Cat or Mono or............................ Nomad Option One 12 05-31-2002 08:48 PM
