#256
(from the M4 site) Specification Waterline length: 4m Overall length: 4.25m Beam (hull): 0.4m Beam overall: 2.4m Mast height: 6.5m Sail Area: 9-10 sqm Hull Weight: 20kg Sailing weight: 45kg well, the all up seems to be about 10lb more, and the sail area looks to also be about 11-22sqf less. so if the M4 goes, so should the SR-71. It almost makes me want to put more sail on it, but having more canvas than a MPS would be silly.
__________________ Samuel Schneider http://sr-71monofoilerproject.blogspot.com/ |
#257
| Your SA is 10.75 sq.m, right? |
#258
#259
| I was talking to a windsurfing buddy today about a new sail that he just purchased (he now has a quiver of 9 different sails), it got me thinking, what do you all think about having three sails available for a boat like this? maybe 12.5sqm 11sqm 9.5sqm like windsurfing. So instead of 1 max sail size. 3 different sail sizes. I know its alot of $$$$$$ to start off, but after your buy in, all the sails would last longer. I was thinking about it because this is a foiler, so you want it to foil, 12.5sqm turns a nonfoiling day into a foiling day, 9.5sqm turns a overpowered day into a ripper, and the average 11sqm will work real nice in your 10-15 blow. Just a thought.
#260
| Good idea,but why don't you come up with a viable reefing system? The RS600FF rig is reefable-when the boat was sailed as a seahugger that system was hardly used -now that it foils they're finding it invaluable. ---------- "So we started developing the RS600 and seeing how it would convert to being used for foils, and I have to say Clive Everest [the original designer of the RS600] designed virtually the perfect boat for foiling, although he probably didn’t realise it at the time! Now with the RS600FF, we have a foiling boat that works for people weighing between 70 to 95kg, it’s one-design, and with the original RS600 reefable rig you can sail the boat a long way up the wind range.” |
#261
A) don't think it would work very well with the Pocket luff/camber induced sail technology B) windage windage windage C) the 12.5sqm would only be used on the lightest days, so the sail would be reefed a lot. D) I hope to move back to the Portland,OR area soon (within the next year), so I probably won't be needing a bigger sail myself. (read GORGE)
#262
| 12.2 sq.m would be the same as the RS600FF-what a power to weight ratio you'd have then.... |
#263
#264
| Fear breeds courage(sometimes) |
#265
#266
Design it himself you ask? I'll wait for the laughter to die down now... |
#267
| Cutting well, It has begun again, cut out the strongback/frame today (the real one this time). Scott "Murf" Murphy doing what he does. Hopefully I'll put it together tomorrow.
#268
| here are the latest images of the R class |
#269
#270
| It looks like the revolution is on its way, and none of dougs "boats" are anywhere in sight. We have a single handed dinghy (moth), a singlehanded trapeze dingy (Sr-71), a two handed foiling skiff (R class), and an all out 3 man super foiler (mirabaud). so where are you going to fit in doug? better start your dumb canting keel sports foiler before theres nothing left for you. ![]() |
| Foiler Design | tspeer | Sailboats | 1031 | 12-17-2010 02:38 AM |
| 3 legged foiler? | sailing_ks | Boat Design | 1 | 04-12-2007 07:16 PM |
| Foiler cat | tamkvaitis | Multihulls | 6 | 02-04-2006 08:03 PM |
| mono vs multi hull | Robert Harik | Sailboats | 6 | 05-16-2004 05:04 PM |
| Cat or Mono or............................ | Nomad | Option One | 12 | 05-31-2002 08:48 PM |
