Old 07-21-2005, 02:58 PM
ridgemd ridgemd is offline
Rep: 10 Posts: 5
26" Bristol, needs new 6HP outboard
I have a 2 stroke 6HP now. It pushes me to hull speed. (It died)
I have the 4 Stroke Suzuki 6HP and the 4 Stroke Nissan 6HP (Both have long shaft) in mind. I am worried that these will NOT perform like the 6HP 2 stroke I have now. Based on the gearing and prop size.
any other suggestions? I have a very small well to go in, so that puts the 8 and 9.9 out of the size requirements.
Also does anyone make the gearing and props for sail applications right now?
bristol built in 1972 by Bristol Yachts, Inc. and designed by Halsey C. Herreshoff has lenght over all 26, length on waterline 21'10'', beam 8', keel draft 3'10'', ballast #2400, displacement #5700, sail area 327 sq. ft.,
Old 07-21-2005, 03:13 PM
Rep: 10 Posts: 5
Picture of small opening
to the well.
Hope this helps. It really just means I can only load in a 6HP.
Old 07-29-2005, 03:44 PM
Rep: 10 Posts: 5
Bought the 6 HP Yamaha, stock long shaft right off the show room floor
Its smaller but fits into the boat.
Performance: Yep is get's me up to 6 knots, a squeaker bit faster than the old 6 HP 2 stroke that got me up to 5.6 knots. Plus NO fumes, and better gas millage. Plus NO mixing gas and oil.
CONS: Going from a 2 cly to a 1 cly engine, means MORE vibration at the high end. Ok at 5 Knots or less.
Noise: Can go one way or the other. They both sounded loud.
But this one spits out lots of H2O for cooling. I felt the water and it hardly gets warm, as so much is going through the system.
Old 07-29-2005, 03:45 PM
Rep: 10 Posts: 5
Change Yamaha to Suzuki
Yamaha would not fit.
Old 08-01-2005, 07:40 AM
water addict water addict is offline
Naval Architect
Rep: 73 Posts: 311
I know this is silly but your thread title - 26" Bristol....
I've never seen a 26 inch Bristol
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 04:54 AM
Inboard to outboard conversion James Francis Fiberglass and Composite Boat Building 16 06-28-2007 02:46 PM
outboard powering a cat EDM Powerboats 9 09-23-2005 06:27 PM
Outboard conversion on displacement hull Allan Powerboats 7 09-13-2005 09:53 PM
Outboard conversion on a displacement hull Allan Fiberglass and Composite Boat Building 1 09-07-2005 02:53 PM
