Old 06-12-2005, 07:42 PM
Seafarer24 Seafarer24 is offline
Sunset Chaser
Rep: 22 Posts: 190
24' Solo-circumnavigator (.dxf file attached)
My current 1974 Seafarer 24 is a fine boat with a fairly intelligent interior layout. I felt that it is the perfect size for a single-handed long-distance cruiser on a budget. However, It lacks a bit of headroom (I'm 5'10") and was designed for vacationing- not live-aboard cruising.
I decided to design a vessel of similar size, but with a different purpose. Here were my design criteria:
24' maximum hull length, not including any protrusions.
4' maximum draft
6' standing headroom throughout doghouse area
1 berth suitable for use at sea
Dedicated Navigation station
Table seating for two
Efficient and effective galley
Workshop space to store sail repair and welding equipment
6' cockpit bench to allow sleeping outside in fair weather
Bridgedeck
Effective bulwarks
Relatively enclosed head, with holding tank
Tiller steering
Looks good
I designed the hull with the hullform program, as it would be built out of plywood. It will have a cutter rig with the staysail going to the stem and a roller-furling foresail on a bowsprit. The aft end of the boom should come down over the transom to allow for a full-width traveler without interfering with the cockpit. Though not shown, I want the keel to have a "leg" which extends along the bottom and ends just aft of the transom. The rudder post will hinge on the transom and also fit into a socket on this keel leg. The rudder will be fairly high-profile and semi-balanced. The mast might be a free-standing (and possibly rotating) design.
I'm just starting to build a 1/12th scale model so I can work on deck layouts and interior designs. I have some old RC airplane gear sitting about so I may even make it a functional sailing model.
Problems with creating an offset file with autoship koen Software 2 08-06-2004 04:37 PM
