#31
| i was looking at getting an old eighteen footer and building a cabin on top and giving it a keel. for you you could use the small rig, take off the racks, and add a keel |
#32
| No, the small rig is still too big for that, you still need racks and or traps. The other problem is that adding a keel puts a lot of load on the rest of the boat that it wasnt designed for. I can sell you one if you want! |
#33
| Thats not really what I want. I want the challenge of designing the thing and if I ever have the cash maybe building one. |
#34
| Evolution vs. clean sheet approach. I think very few even professional designs out there are a complete clean sheet design but rather an evolution of an existing design. Given above, here is what I would do. 1, Do a detailed specificaion of your boat. This should include not only measurements but also what objectives your boat should fulfill, budget and material choices. 2, Search for exisiting designs/boats that come as close as possible to your target specifications. 3, Modify/combine the designs to get your final design closer to your target specifications. As an example, this is how I got about for my last boat. Objectives: - High performance sportsboat - Be able to sail and race on club level single handed up to 20 knots wind - Sail mostly single handed but also be able to take on a friend/child. There is no exisiting boat that fulfills above objectives. I didn't want to build something (different from you), so I search for existing boats which I could do as small modifications as possible. In so, I listed some target measurements on the boat. - Around 18 feet long - Easily driven hull with as small sails as possible - Self taking jib - Gennaker with a chute (aka tunnel) - Raced in original way with as few people as possible preferable two - Self righting after potential capsize After searching the market I found that the RS K6 came closest to above. I did following changes: - Fitted a trapeze to equal original RM of two people hiking. - Changed gennaker halyard and pole control lines to the bak of the cockpit The result is a boat that is faster than the original and I can race it in tight manouvers including using the gennaker in wind speeds up to 20 knots. Cheers and have fun |
#35
| Use an aluminum plate for the CB... INDY
__________________ To go where others have gone..... To see what none have seen.... |
| Northwest 21 Trailerable Yacht | Duker515 | Sailboats | 65 | 09-08-2010 10:34 PM |
| 18ft molds | Nick F | Fiberglass and Composite Boat Building | 3 | 09-11-2009 05:38 AM |
| The Ideal 18ft Daysailer | Paulo.AS | Sailboats | 25 | 10-06-2008 07:58 PM |
| Customizing an 18ft fiberglass | svonmiller | Powerboats | 3 | 10-02-2006 08:20 PM |
| Need to build a 18ft Aluminum Boat | myles king | Boatbuilding | 1 | 06-24-2005 10:20 PM |
