Closed Thread
  #61
Old 03-12-2009, 06:54 AM
Doug Lord
Trapwing
The system on the trapwing will be capable of moving the crew between 3' and 4' in one second-faster than any "human" crew. And do multiple quick moves at that speed over a long period.
  #62
Old 03-12-2009, 06:06 PM
mark_m mark_m is offline
Rep: 27 Posts: 9
It takes less than a second to get out on a trapaze, which is a move of about 4' so I don't see how that is true.
Let's assume that a blind, deaf crew with very fast reactions can adequalty balance a boat, then this implies that ~500w is an adequate motor size to power your robocrew. I didn't notice how sensitive the power requirement is to crew movement time. It looks like a 2second transit of 9 feet only requires ~500w output.
I accept that my initial assumptions may have been overly pessimistic and that a much smaller motor and hence battery may be feasible.
However, I think your (Doug and Rick's) estimates of the crew moving once every few minutes are very optimistic. They may be true sailing in very steady strongish wind on the sea with big courses. On my local lake you can't sail for three minutes without hitting a bank!
check out this video of somebody sailing a musto skiff in marginal conditions: http://www.youtube.com/watch?v=xIWIoUcgWhU
Those conditions would count as steady where I normally sail. He is continually moving in and out when going up wind.
I initially assumed a 3% usage rate but I now believe 5% may be better for your calculations. If I was designing the boat I would assume 100% usage because of my local conditions and for a factor of safety.
I agree with Bill though, these challenges are what interests me but they are still minor compared to the system design and integration issues.
I'm confused as to why you didn't put your own numbers into the model to see for your self.
I thought you might find this interesting:
http://www.youtube.com/watch?v=jrn9V...eature=related
(a Musto Skiff, with an electronic crew and no keel lead)
  #63
Old 03-12-2009, 06:45 PM
Doug Lord
Actually, Mark, the requirements can be widely varied and still have more than enough power for a days sailing with a small battery. Speed is excellent and also proportional so no matter what the conditions are the skipper will be able to move the ballast the way it needs to be moved for top performance.
I appreciate your effort in looking into this concept. Now, that you may have a different perspective on what is possible do you have any interest in looking further into it?
That MustoRC is great-thanks! I bought one of his early boats. Did you see the MelgesRC above? Also did a microMoth, catamaran,tri and scow using the "Trapeze Power Ballast System". Worked well(the Moth was problematic) and was a blast to use-really adds to RC sailing. Too bad most rc sailing class rules prohibit movable ballast.
I think the trapwing concept has a lot of potential and am adding it to the boat I'm building now. It was always in the cards that this would be one of the experiments done with my new boat which will be "convertable" between a straight foiler and this boat-it is an experimental platform. I already have two experimental rigs,two sets of foils and all the small pricey rigging parts. The mods to the hull are my focus now as well as finalizing the wing design. The hull is very narrow and not ideal for a "forgiving" application of the trapwing but will explore the wild side of the concept(no initial stability)-starting with 100sq.ft. of sail and 80 pounds of ballast and working up to 160lbs. and 160+ sq.ft.. with a 12'+ wing.
16-18' "Sit-in" Planing Monohull ("Trapwing")-p3060080_small.jpg  16-18' "Sit-in" Planing Monohull ("Trapwing")-pbsdemo.jpg  16-18' "Sit-in" Planing Monohull ("Trapwing")-p3060072_small.jpg
  #64
Old 03-12-2009, 07:13 PM
Steve Clark's Avatar
Steve Clark Steve Clark is offline
Charged Particle
Rep: 153 Posts: 98
What I don't understand.
I guess I just don't understand what advantage this boat has over a small trimaran of equal beam.
The Challenger being one example.
As near as I can tell, the trimaran will have superior performance with less complication.
SHC
Beatings will continue until morale improves.
  #65
Old 03-12-2009, 07:18 PM
Paul B Paul B is offline
Rep: 6 Posts: 1,692
SHC
Simple:
Gadgets!
Not to mention FAME for the great designer of this "technology" (circle R, patent pending).
  #66
Old 03-12-2009, 07:19 PM
Doug Lord
I'm not at all sure of that,Steve-particularly for the self-righting version. It has more SA than a WETA-and the power to carry it.
challenger tri: http://myweb.tiscali.co.uk/sailchallengers/
Challenger
LOA 14.76
SA approx. 80sq.ft.
Weight-308lb.
Weta
LOA 14'
SA 123.9 sq.ft +spin
weight-220lb( some have said the Weta is 240 all up)
Trapwing
LOA-16-18+
SA 160sq.ft. +spin
Weight-271-320lb.
  #67
Old 03-12-2009, 07:41 PM
Rep: 593 Posts: 2,054
The sail area for the Weta is incorrect, as is the all-up weight.
If you want to sell something, then have the decency to represent the competition accurately.
  #68
Old 03-12-2009, 07:44 PM
Doug Lord
You,sir, are dead wrong-AGAIN!!!(ABOUT THE WEIGHT) But you're right about SA=123sq'-
http://www.sailweta.com/specifications.html
Challenger
LOA 14.76
SA approx. 80sq.ft.
Weight-308lb.
Weta
LOA 14'
weight-220lb(some have said the weta is 240 all up)
Trapwing
LOA-16-18+
SA 160sq.ft. +spin
Weight-271-320lb.
  #69
Old 03-12-2009, 07:51 PM
Actually, no Doug, I'm not.
http://wetatrimarans.com/Weta_Specs.htm
The Weta has a MAIN of 89 sq. ft. and a JIB of 34 sq. ft.
The weight, Rigged Total is 220 lbs.
The is the East Coast US distributor of the boat. Just a few miles up the coast from you. You should get to know them.
Say you are sorry now and go back to the fuzzy room.
  #70
Old 03-12-2009, 07:52 PM
Rep: 6 Posts: 1,692
You,sir, are dead wrong-AGAIN!!! But you're right about SA=123sq'-
Dead wrong, but right!
Now that is talent.
  #71
Old 03-12-2009, 08:00 PM
You had incorrect figures to begin your so-called power point and you got nailed for spewing the fake to make your claptrap wingy look good.
Does it occur to you at all, that we can all see you there, scurrying around with the fever.
Now, say you are sorry. We are all waiting for you to man-up.
  #72
Old 03-12-2009, 08:04 PM
Doug Lord
Interesting comparison. The Trapwing is a bit heavier but much more powerfull. Would be an interesting race with the edge to the monohull,I think.
Weta
LOA 14'
Trapwing
LOA-16-18+
SA 160sq.ft. +spin
Weight-271-320lb.
  #73
Old 03-12-2009, 08:10 PM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
you can do self righting with small tris too
  #74
Rep: 6 Posts: 1,692
Weta
LOA 14'
Trapwing
LOA-16-18+
SA 160sq.ft. +spin
Weight-271-320lb.
I wonder how this could be accomplished?
Something that actually exists racing against something that isn't even up to the being called vapourware?
A real boat racing against a collection of numbers typed onto a screen?
  #75
Old 03-12-2009, 08:13 PM
Cheesy Cheesy is offline
Rep: 182 Posts: 288
As you already have some power consumption figures what actuator and control system are you going to be using? off the shelf?
Closed Thread
Neo 495-Small French "Sit-In" Keelboat Doug Lord Sailboats 29 09-29-2011 09:02 AM
CMD "project Zeus" VS VOLVO "IPS" gerard baladi Pod Drives 13 09-10-2007 10:23 PM
Boat "workshop" including a "testing tank" zmfmd Open Discussion: All Things Boats & Boating 0 08-08-2007 05:43 AM
"Free" 3D modeler "similar" to Rhino CGN Software 0 05-14-2006 11:56 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 03:03 PM
