Old 09-02-2008, 11:55 PM
Doug Lord
Originally Posted by Munter View Post
Hi Doug.
How many foilers have you seen begin foiling when not pretty much bolt upright and how to you propose to maintain that in a keelboat?
Munter, in normal sailing the boat's RM comes 100% from the crew moving
outboard on racks using sliding bench seats. The keel bulb provides no righting moment as on a "normal" keelboat. It's there just to recover from a knockdown and/or pitchpole.
Old 09-03-2008, 01:57 PM
Doug Halsey Doug Halsey is offline
Rep: 65 Posts: 45
Originally Posted by wind_apparent >>
After I get the SR-71 finished and working well, I'm going to make one of these for the Ol' family boat.
Wow, what a surprise! Here I am innocently reading about hydrofoil keelboats, when I come across a photo of my little hydrofoil trimaran Broomstick. And then to have it referred to as a possible family boat!
Here's another photo of Broomstick, with a much better family boat in the background. Those guys (& some girls) were really having a great time that day.
Maybe when I get this boat working better, I'll take a stab at a monofoiler. Should be lots better in lighter winds, at least.
Seriously though Doug L. : I think you & most other sailors would probably be disappointed in the performance of the boat you're proposing. The extra drag of the foils when you're not foiling & the extra weight of the keel when you are would be real killers, in my opinion.
Some experience from sailing Broomstick (admittedly a much smaller boat):
1- I like to sail as often as possible without the amas. I can really feel the difference in performance with 20 lbs. less weight.
2- I really don't like to use my bigger rig (143 ft**2, instead of 108), in part because of the extra 20 lbs. that it adds.
3- I tried sailing the other day with a daggerboard, in addition to the foils (hoping to improve the performance going to windward). The drag of the added wetted area made it feel really sluggish.
You've got a lot of other ideas to work on. Please put this one on the back burner for now.
Regards,
Doug Halsey
Old 09-03-2008, 02:26 PM
wind_apparent's Avatar
wind_apparent wind_apparent is offline
wind driven speed addict
Rep: 96 Posts: 257
no,seriously, I love your little trifoiler and would love to build one to take my kids out on the weekends. they love fast boats and so do I. sometimes we go out on a hobie 16 on windy days and they love it. Did you design it? Are the plans available?
Samuel Schneider http://sr-71monofoilerproject.blogspot.com/
Old 09-03-2008, 04:42 PM
bistros bistros is offline
Previous Member
Rep: 0 Posts: 534
Reality Check for the Black Knight of Foiling
Originally Posted by Doug Lord View Post
LOA 16-17'
Beam 12' (easily foldable for trailering)
Hull+ rig ready to sail weight 160lb.(minus ballast)
Ballast in bulb keel-120lb(self-righting from capsize or pitchpole) only etc.
Crew weight nominal 320lb.(sliding bench seat)
Upwind SA 150 sq.
Downwind SA 300 sq.ft.
Mainfoil on keel strut(at bulb)
Rudder foil
I kind of doubt it would be self-righting. 120 pounds isn't a lot of RM on a 5-6' lever arm. Getting a normal two man performance boat back up isn't trivial with a 120 pound person. Generally lifting a wet rig without the vang blown is tough. Widebodies (12') of any configuration have their own issues - not the least of which is that buoyancy pods/amas/whatever aren't selective about how and when they provide buoyancy. Once a boat is turtled, buoyancy pods make it harder and not easier to right.
Although people have tried unsuccessfully before to table this issue, weight is the enemy of foiling - higher weight requires a higher lift component generated from the foils, and a higher lift component means higher drag. Higher drag means more power required from the rig, and higher righting moment to keep it level and working.
I just can't see this idea working well, power to weight ratios, SCP and whatever statistical fact mutilation/reality avoidance technique you prefer. "Foiling sportboat" just seems kind of .... oxymoronic.
I understand the simplistic appeal of making foiling popular and easy - kind of like making rocket science simple, solving quadratic equations easier than adding 1+2 or getting a simple accurate manual on how to figure out what women are thinking.
Face reality - your "easy to foil" foilers were already built, but there wasn't a thundering stampede to buy Raves or Hobie Trifoilers. Foiling isn't the holy grail of sailing to most people, and years of unbalanced promotion of foiling in any form haven't seemed to made you popular.
Maybe unskilled operator foiling for big folks and jumping foilers is YOUR personal Holy Grail and you are confusing YOUR hopes and dreams with everyone else's. I know whenever I read another Doug Lord spec sheet on foiling I feel like breaking out the coconut halves to make the hoofbeat noises as you chase the Holy Grail, just like the Monty Python comedy you seem to be emulating.
I know you will respond in Monty Python fashion (just like the Black Knight) "It's just a flesh wound" as your arms are cut off.
Old 09-03-2008, 06:28 PM
Doug Lord
Regards,
Doug Halsey
Thanks for the comments,Doug! This little boat is just an idea for the time being-most definitely on the back burner! However,I think it could work....
If the boat was designed properly the foil lift would reduce hull wetted surface and wavemaking drag from a surprisingly low speed on up. Total wetted surface including the foils could be equal to or less than other monohulls its length. It's an interesting design challenge with the concept of "foil assist" playing a major role.
Old 09-04-2008, 04:51 AM
Rep: 385 Posts: 1,248
self righting 5 metre foiler
Doug, thinking about the self righting - have you seen Randy Reynold's ideas of self righting his R33? - such a layout, modified somewhat, could be achieved on the "fictional at this stage" SR5 - or is that cheating? Anyway I'm thinking about it while lying in the bath - where, of course, all the best designs are conceived.
Old 09-04-2008, 07:05 AM
Doug Lord
Haven't seen that Gary-is that a system where the boat "self-rights" w/o crew action ? Tell me about it when you get a chance
Old 09-04-2008, 05:07 PM
Sr5
Actually he swore me to secrecy - so I'm not saying anything but like all good ideas, it seems obvious once you see it and his self righting concept definitely has advantages (and a couple of disadvantages too) - but it works.
Old 09-06-2008, 11:25 PM
Doug Lord
Ok, this was two years ago-come on spill the beans(please):
"Righting System
There are three different systems being developed to make any capsizing of an R33 a non-event. One of the systems is almost complete with just the finishing touches to be done. It has been tested twice already with four crew capsizing the boat under sail. “It worked so well we can’t wait to do it again, said Reynolds. “It was fun! And we didn’t even get wet…both times!”
The systems will be very user friendly and once fully operable will make the R33 the only multihull on the market with such a safety system in place. While other performance boats encounter the risks inherent in the sport and adopt a “use at your own risk” policy – Reynolds Design is determined to make their boats their sailboats the safest boat on the market for their size."
http://www.r33.com/en/update/jan06.asp
And I found this here-http://reynoldssailing.com/en/update/pdf/NewsletterApril06.pdf
Refering to a masthead float?
“It happened real slow – it wasn’t like you couldn’t react. Once we started going up I was concentrating on the
main and the traveler and I wasn’t thinking about the jib. By the time I said cut the jib, our bow had blown off too
much to make any difference.”
The silver lining was that Dunbar was prepared for the situation by having his float bag that included his hand
held radio, IPERB, tow boat membership and cell phone all in an accessible location. And more importantly, the
capsize-related Reynolds designs worked excellently. An anchor system that Dunbar had Reynolds provide was
deployed and the newly designed mast float made the event extremely manageable.
“The float worked well,” said Dunbar. “It completely floated the mast and did what it was supposed to do.”
Dunbar was able to call the pre-designated tow company and drive the boat home - with no damage - under its
own steam.
  #25
Old 09-08-2008, 02:25 AM
R33
The first system - but my lips are sealed.
  #26
Old 03-29-2009, 09:05 PM
Doug Lord
Foil Assist Upwind
I would like to hear some comments from people knowledgeable about foiling on one of the central themes of this thread: the foils would not be retracted but would be designed to be effective upwind from,say, 5-6 knots boat speed on up in reducing hull wetted surface and thereby "paying" for their wetted surface/drag. Off the wind,when the spin is popped the boat would fully fly.
But the "foil assist" aspect of this concept is important and I'd like to get feedback on the idea. Thanks in advance......
  #27
Old 03-29-2009, 11:27 PM
fng fng is offline
Rep: 46 Posts: 39
some mad buggers had a go on a larger scale, primerily the foils were for stability and windward lift. The foils were ment to be smaller and have less drag, but the engineers wanted more carbon. End results - stability gained, well a carbon rig would have been better. windward lift outstanding at times but very hard to get into the grove out of tacks. In the end it was thought that the gains were not enough to warrent continuing, so the cut it all out and fitted a tone of water ballast each side and the boat went way better .
16-17' Fixed Keel Self-Righting Foiler-m1-wing-things151.jpg  16-17' Fixed Keel Self-Righting Foiler-m1-wing-things152.jpg
  #28
Old 04-02-2009, 07:17 PM
Doug Lord
Upwind Foil Assist
I'm convinced that a properly designed system that uses "foil assist" to help the boat upwind and then allows it to fly when power is doubled downwind is viable-and a great potential use of hydrofoils.
We know that upwind foil assist can work with many examples from the I-14 to the Catri and Open 60 tri's to the Stealth beachcat-it just hasn't been explored in the direction I'm thinking of in this thread as best I can tell. But it will be-I'm certain of that.
  #29
Old 04-03-2009, 08:06 AM
Previous Member
Rep: 0 Posts: 534
We know that upwind foil assist can work with many examples from the I-14 ....
Huh?
One of the most active I-14 fleets in North America is at my club, and the only use of lifting foils on I-14 RUDDERS ONLY is to control pitch, not to provide lift for the purposes of reducing wetted surface area.
People crank on a little rudder lift to help keep the bow down and allow crew on the wire to trap further aft. Keeping the bow knuckle just touching the water is critical for upwind speed. Allowing the crew to trap aft keeps the two people on the traps together - reducing aerodynamic drag and making transitions through the twilight zone safer.
Doug, please don't represent the use of a T-foil rudder on an I-14 as foil-assist in the same sense as a hydrofoil boat that can "foil" downwind. All you do is provide the guys in the bar with more reasons to laugh at your ignorance of performance dinghy sailing. I-14s have outlawed the use of more than one lifting foil on the boat, effectively preventing foiling as a class direction in the future.
Alan Smith and Dave Lugg's foiling I-14 many years ago was no longer a class legal race-able I-14 once the rules changed, and there is no I-14 class motivation or interest (democractically) in going further down the foiling path.
But them again, you won't listen.
Bill
  #30
Old 04-03-2009, 01:51 PM
Paul B Paul B is offline
Rep: 6 Posts: 1,696
Bill
Of course this is simply another waste of time. The King of Kooks dredges up a 6 moth old thread with more of his repetitive nonsense, asking a rehetorical question he doesn't want an answer to for the umpteenth time.
He simply needs to divert from the real topic, that he has a garage full of useless parts that will never be a funtional vehicle.
Same old craziness. It will never end, and no actual boat will ever emerge. Hell, the dolt can't even produce a technical drawing.
Meanwhile, others are building and sailing, some even foiling, their projects.
Making yer own fixed portlights yorktownie Fiberglass and Composite Boat Building 16 07-13-2008 09:21 AM
BeachCat DagggerBoard vs. Cb vs. Fixed Keel jtremolo Multihulls 5 06-16-2008 05:34 PM
keel conversion - fixed to lifting bart streb Sailboats 17 10-26-2007 02:17 PM
righting moment of a keel rapscallion Stability 4 10-17-2007 10:15 AM
Twin Keel Righting Moment Willallison Sailboats 23 04-04-2006 01:22 AM
