| 12v Bilge pump timer/delayed shut-off...? Does anyone know of a 12v timer that would/could be activated by a float switch? I’d like to have a automatic bilge pump that pumps all the water or virtually all the water from the bilge area. Not just one that pumps until the float switch goes down/off. You can never get a bilge pump to pump all the water from the bilge on a automatic float switch. If the pump is lower than the switch then that amount it’s in water still when the float switch shuts it off still remains and if above the switch well you figure it out, you’ve obviously still got water left in the bilge area. I’d like to have something that continues to let my pump run for a short spell after the float switch has switched off! ![]() |
| have used SEE WATER water smart pump switches for some time.they have a ss probe that turns on pump when the water touches it. the pump runs for an additional 8 seconds when the water level falls below the probe level. have had great success with them and they outlast any mercury or metal ball type float switch i have tried. cost about 50 bucks. |
| have used SEE WATER water smart pump switches for some time. Google doesnt bring this up , any source? FAST FRED |
| I have used the Rule automatic bilge pumps for years. There are NO external floats. It does pump down to zero water of the spinning impellor. Then runs 10 more seconds and shuts off. Guard pulls off and the fine screen is great to clean. VERY reliable unit. ITT owns Rule Pumps. On the web. |
| Now that my web access is fully working once more... you need a few resistors, a couple of capacitors a transistor, a relay and an NE555 timer chip. With a little electrical know-how (which can be gained with a bit of google searching) and a bit of board to build it on, and a box to put it in, you can build it yourself. for $10 to $20. That would be my favoured way to implement a delay circuit. Tim B. ps. search for: 555 monostable ic ciruit diagram
| bilge keels | roxanne parola | Sailboats | 21 | 03-10-2006 11:35 PM |
| Fuel Pump or no? | seaARK03 | Powerboats | 4 | 10-26-2005 06:18 PM |
| bilge Pump monitor | odyssey11 | Marketplace | 0 | 10-24-2005 07:05 AM |
| Bilge Pump Protection | tony.young | Electrical Systems | 16 | 02-22-2005 08:41 AM |
| Bilge pumps | redcoopers | Sailboats | 4 | 09-19-2004 06:36 AM |
