Go Back   Boat Design Forums > Design > Propulsion > Props
Old 08-20-2011, 03:27 PM
rich99uk rich99uk is offline
Rep: 10 Posts: 43
What Size Prop for Mitchell 31 MK1
Hi
I have recently Purchased a mitchell 31 mk1 which i have been doing up.
It didnt have a engine or any stern gear init when i got it, However thats all sorted now I Just need a prop but i have no idea what size to get?
The Boat is a mitchell 31 mk1
Engine is Ford Dover 2725E 130HP Fitted with heavy duty Fly wheel
Prm402D Gearbox 2:1
weighs About 4 Ton
Is there anyone that has the same boat that can tell me what size prop they have got?
Or has anyone got a cleaver way or working it out
Many Thanks
Rich
Old 08-21-2011, 02:28 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Google for propeller calculation, there is plenty on the web.
You must know the engine rpm that belongs to the 130 hp maximum power, take 2/3 of that as cruising rpm and divide by 2 to get prop rpm. The outcome will probably be approx. 1000 rpm or a bit less. Then select the prop that gives you hull speed at that point, so you get good economy and have some reserve for bad weather.
Prop size? piperca Props 15 02-19-2011 02:17 PM
What size Prop to use Jimboc Props 6 02-05-2010 06:00 PM
what prop size do i need? dmcc Surface Drives 5 06-11-2008 06:35 PM
Prop size wireguy Sterndrives 3 09-01-2007 12:24 PM
prop size? maxum Powerboats 7 05-22-2007 06:11 PM
