Go Back   Boat Design Forums > Design > Propulsion > Props
Old 06-13-2006, 05:59 PM
Poppajoe Poppajoe is offline
Rep: 10 Posts: 6
What prop?
Can someone help please?
I have used various prop calculators and I am getting more confused.
I have an 18ft Icelander fishing boat with a ford xld 1.8ltr, 60hp diesel through a Volvo 280 single prop drive.
Details below, but I need to know what sort of revs I need to be running at.
The prop calc suggests 14x12 or 15x15 depending what hull shape, tried both and with 15x15 she bogs down at 2300rpm at about 11 knots, with the 14x12 she runs at 2800rpm at about 14 knots.
The calc suggested 17 and 23 knots respectivley, in fact with the details entered at their worst case senario I could not get a figure below 17 knots suggested.
I would presume that smaller dia and larger pitch (ie 12x17) would reduce revs?
I am not looking for any particular speed but want to obviuosly run at the highest possible. I am not concerned with fuel consumtion and do not mind wearing out an engine at around 500/1000 hrs.
I can post a pic of boat showing hull if it helps?
waterline length = 16ft
max revs = 4800 (60hp)
max torque = 108 NM @ 2500RPM
drive ratio = 1.89:1
boat weight = 1300kgs (max checked on weighbridge)
max prop dia = 15"
Hull form? = on plane would be very shallow "v" about 10 degrees?
Any help would be much appreciated.
Old 04-19-2007, 11:26 AM
Çemberci's Avatar
Çemberci Çemberci is offline
Rep: 104 Posts: 109
Propeler Size
max prop dia = 15"
Dear
Limited Hull data the result is below:
Diameter = 12.00 inç
Pitch = 9.5 inç
Dar =% 92.62 - 21 cm or 8.2 inç
3 bladed
Oktay Çemberci
oktay@cembercidenizcilik.com
Old 04-19-2007, 12:22 PM
Jango Jango is offline
Senior Enthusiast
Rep: 55 Posts: 456
I believe the HP given is Brake HP, which should be reduced by approx 25% to obtain Shaft HP.
Using "Prop Calc" , the results are:
Max Speed - 16 knots
Prop - 12 x 10, 3 blade, D.A.R, 55% , 20% slip
RPM should be close to 4800 unless Displacement is higher or motor not producing advertised HP.
Old 04-19-2007, 12:46 PM
Çemberci's Avatar
Rep: 104 Posts: 109
If the DAR % 50
Prop - 12.00 * 10.50 inç 3 blade
oktay Çemberci
Prop Shaft LADYLOVE Propulsion 0 04-30-2005 12:26 PM
Sizing a prop?... DrKirk Sailboats 14 10-06-2004 01:58 PM
Prop performance danmarine Boatbuilding 0 05-20-2004 12:58 PM
Prop performance danmarine Fiberglass and Composite Boat Building 0 05-19-2004 06:03 AM
max -prop mike buchan Sailboats 1 01-25-2002 07:53 AM
