| ventilated props ? from Boattest.com ventilated props? reminds me sort of the yamaha props that could break and reverse better by reversing the exhaust flow but this sounds even better, where do we start drilling? |
| these props are used a lot on bass boats mercury makes one that has inserts so one can change the size of the vent for better performance without having to drill |
| A simpe idea, but dos it work? Expecting members to try it out ![]() |
| Should work. It will reduce the delta-P between the pressure and suction faces during high caviatation. On the other hand it will lower rho in the non-cavitating region and mangle the ability to back. There was some expermental work in the 50's and 60's on similar stuff for big wheels, too complicated to justify. Better performance gained by going to slightly bigger, slower turning wheels.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| these props do work when used correctly examples of this prop are: yamaha -performance 3-blade mercury -typhoon and lightspeed evinrude -raker and rakerII i've also used them on some go fast I/O's not just outboards |
| I don't get any sound in the video (old computer). I did see what looked like a hole which could provide air or a water jet flow over the blade. How does it work?
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
| Piranha props | razbarb | Outboards | 1 | 05-08-2007 01:07 PM |
| What props sould I have? | goodidea28 | Inboards | 10 | 04-15-2007 12:52 AM |
| Do more props help ? | smilingjack | Hybrid | 1 | 10-27-2006 08:17 PM |
| Forward props | Akeswins | Props | 8 | 06-10-2005 09:48 PM |
| duo props | tooty | Powerboats | 3 | 11-14-2003 09:52 PM |
