Go Back   Boat Design Forums > Design > Propulsion > Props
  #31
Old 03-29-2010, 08:38 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Fred
I dont think the very high pitch at low speed woud cause it to cavitate as the blade loading would be very low for the low speed as we know you are only using very small power....
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
  #32
Old 03-29-2010, 07:32 PM
apex1
Originally Posted by FAST FRED View Post
I think there is no way a CPP is going to be able to properly load an engine at VERY LOW RPM , with out having the pitch cranked up to the point where the prop will cavitate .
Perhaps Rick could answer this question ,
FF
Two very dangerous assumptions!
First,
you do NOT understand a CPP. (and quite obvious, you do not like to learn it)
second
Rick is the last one I would ask for anything related to real life propulsion.
He might be pretty capable of operating programs, but thats it. He knows NOTHING!!!!!!!!!!!!!!!!!!!!!!!
.........except the right theory
So, go on with your ideas, and do not play this idiotic game any longer! We know you do´nt like CPP systems (and that you do not know them).
  #33
Old 03-30-2010, 06:20 AM
Rep: 756 Posts: 3,328
I operated a heavy 55 ft motor sailor double ender in wood with a Hundstead CPP , no clutch for a season.
While the unit was both efficient and easy to learn , it did have its own operating requirements. Mostly you had to speed up to about 750 RPM before shutdown , and set the pitch to neutral at that RPM.
On start the engine would be advanced and monitored for the first 5 min of warmup to stay at that rpm, or the boat would move, dramatically as the prop was about 30 inches.Ant RPM change was motion!
On a motorsailor it was a great concept , but I'm not thinking of a motorsailor , but a boat that will have a slow cruise regime , most of the time.
Remember when the boat is at 20k THE WATER IMPINGING THE PROP IS ALSO 20k At 10k the water is also 10k so the amount of pitch from 20K will be far too much . Since the only (fixed diameter) way to load the engine is with pitch , i sure do worry the prop will simply boil the ocean.
I would love a vessel with CPP , and 2 speed tranny, as I am used to aircraft where full prop controls are the norm, bur weather the cost of the unit would ever be returned in a cruising pleasure boat is a concern.
FF
  #34
Old 03-30-2010, 10:42 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
You make an assumption of equally high engine loading. In such broad rpm range operation you need a pyrometer to get engine loading inside the acceptable range. This way the real engine loading might be somehere btw 40 to 100%.. Anyway with a large prop enough you will never cavitate at low rpm even with prop blades at 90deg angle.. Some sidewalking might happen thou..
  #35
Old 03-31-2010, 06:17 AM
"You make an assumption of equally high engine loading."
The desire is to properly load the engine at minor RPM as with a "normal" prop load the engine can consume 2/3 more fuel per hp
"a pyrometer to get engine loading inside the acceptable range"
No problem a pyrometer is about $100 US .
"Anyway with a large prop enough you will never cavitate at low rpm even with prop blades at 90deg angle.."
Remember to gain efficiency the prop will be a 2 blade , of large diameter , so tip cavitation IS a concern
FF
  #36
Old 03-31-2010, 07:46 AM
TeddyDiver's Avatar
Gollywobbler
Engine rpm at idle 750, lets say 2.7 reduction means about 270 prop rpm, 20"/50cm prop would be ~6.6m/s tip speed... Typical power curve for 70hp/3600 diesel says 28hp at 750, lets assume 60% eff means ~17hp.. Cant go further without assumpions of the boat restance too.. However I've never seen cavitation marks in a prop under these circumstances..
Baeckmo! need some expert opinion here
ps. Something related..
http://atljsoft.com/HTML_Help/Calcul...n%20Number.htm
  #37
Old 04-03-2010, 05:49 AM
The latest issue of Pro Boat Builder (free on line) has a good article on the efficiency topic.
Seems the Gori prop with built in shift ability to "overdrive" could solve the problem at a lower cost than a CPP.
True it could not be optimized as well for every condition and sea state as a CPP, but at $10k to $20K cheaper ,
and that it can easily be retrofitted , or removed for the "next " boat,,,,,,,
FF
  #38
Old 04-03-2010, 07:19 AM
TeddyDiver's Avatar
Gollywobbler
Changing pitch is fine for minor differences in propulsion , but an engine sized for flank at 2100rpm is never going to be efficient when throttled back to 1000rpm for long range cruise.
My simple solution ( But really pri$y) is a ZF 2 speed tranny , speed up the shaft speed at LRC to increase the load .
The graphs say it will work ,(and its a simple purchase) but changing diameter would work even better , but I have never heard of the variable diameter concept.
etc...
Please FF, you can try whatever gizmos but you refuse to consider something what's reliable and well tested for decades..
CPP
  #39
Old 04-05-2010, 05:59 AM
Gori has been building props for decades,
if we gave up on any innovation till proven by decades we would still be using silk and bamboo to build 777's.
The question is to solve a problem ,,,, a standard prop is underloaded at most cruise speeds , and the engine is a huge inefficient fuel consumer at light loads.
Variable pitch might help , but for us in the real word with recreational vessels , COST does count , unlike the commercials that may run 2000 hrs a year where a 30%-50% saving can be big bucks.
FF
  #40
Old 04-05-2010, 07:32 AM
Rep: 418 Posts: 777
"The question is to solve a problem ,,,, a standard prop is underloaded at most cruise speeds , and the engine is a huge inefficient fuel consumer at light loads."
Thinking out loud here. One time tested solution to this problem, engineered in the field by pragmatic sportsmen is the kicker concept for trolling.
Another point to ponder, at what point does it become acceptable to to sacrifice flank speed for a suitable level of cruising speed effiency. For me I'd happily make the trade off at 12-15 knots.
  #41
Old 04-05-2010, 08:17 AM
TeddyDiver's Avatar
Gollywobbler
"Variable pitch might help , but for us in the real word with recreational vessels , COST does count"
Why you don't make a real comparison instead of guessing?
http://www.kastenmarine.com/CPprops.htm
"if we gave up on any innovation till proven by decades we would still be using silk and bamboo to build 777's"
Of course there's nothing wrong with new innovations, but so far there's nothing better available.. btw bamboo and silk are great materials
BR Teddy
Prop diameter and gear ratio tuantom Powerboats 12 01-21-2008 01:01 AM
Prop pitch & diameter mikey483 Outboards 2 04-25-2007 10:03 PM
Catalac 8m OB 2-Stroke 45hp prop pitch & diameter question..? paularey Boat Design 1 01-25-2007 04:55 PM
OB 2-Stroke 45hp prop pitch & diameter question paularey Outboards 0 01-25-2007 05:44 AM
OB 2-Stroke 45hp prop pitch & diameter question..? paularey Sailboats 0 01-25-2007 05:42 AM
