Go Back   Boat Design Forums > Design > Propulsion > Props
Old 04-24-2008, 01:26 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
Use of Bp~Delta diagram for prop selection
I am learning to use the Bp~Delta diagram for propeller selection.
The process i go through is:
at first i assume a suitable and reasonable value of rpm and shaft power.
then according to calculated Bp ; using the optimum efficiency line i find the value of delta and p/d and from the value of delta i can find the diameter.
But if the found open water efficiency doesnot give my required effective power then i run along the fixed delta curve(with delta value previously found) changing the rpm (power is constant) and i find new values of diameters.
then i plot a Diameter vs Effective power curve and select the diameter gives my desired effective power.
I dont have good books on propeller selection. So want to know how much right my process is and what additional things should i do to select the propeller.
thanks in advance
Prop Selection CMARSHALL Props 3 07-03-2006 04:44 AM
New question prop selection simso Propulsion 0 09-01-2005 04:47 AM
Prop selection again simso Props 5 08-31-2005 03:54 AM
Prop Selection TJB621 Open Discussion: All Things Boats & Boating 0 02-07-2004 03:52 PM
prop pocket or delta section? kapnD Boat Design 3 09-21-2003 05:39 PM
