Go Back   Boat Design Forums > Design > Propulsion > Props
Old 11-08-2011, 08:30 AM
svfrolic svfrolic is offline
Rep: 10 Posts: 12
universal shaft strut?
I need to replace shaft strut on my sailboat and I was thinking about using one of this universal struts
http://www.buckalgonquin.com/pages/P...trut_page.html
The thing is I am more familiar with this type of strut which is bolted thru the hull like my old strut was. The problem is I couldn’t find strut with dimensions that would fit my boat so I think about the universal strut. The question is what would be the best way to attach it to the hull; just glass it in…?
Old 11-10-2011, 06:33 AM
Bglad Bglad is offline
Rep: 67 Posts: 156
I took a quick look see around for an adjustable strut I saw on a boat recently but couldn't find one. It might be a good option if you can. It was bolted or glassed into the hull (can't remember) but the barrel was bolted to the leg so its angle could be adjusted and it could be removed for bearing replacement.
universal shaft strut? svfrolic Inboards 2 11-08-2011 10:54 AM
Universal Sailboat Strut Installation svfrolic Boatbuilding 0 11-07-2011 10:21 AM
FRP shaft strut mikereed100 Fiberglass and Composite Boat Building 17 12-13-2009 10:03 AM
Stainless V Strut vs Bronze V Strut jameshogan Materials 7 05-17-2009 07:03 PM
Shaft Strut Corroded WaterDog Metal Boat Building 3 04-17-2008 11:24 PM
