Go Back   Boat Design Forums > Design > Propulsion > Props
Old 06-20-2005, 11:49 PM
manunk manunk is offline
Rep: 10 Posts: 3
Surface percing propeller matching problem
Dear all,
Now, I am evaluating a Boat (displ. 16,3 T) propelled with Surface piercing propeller ( Pitch : 28", diameter :23,5", and six blade). recent sea trial test result show that the engine (CAT 2 x 570 HP) is run in a overload condition for a normal speed operation. then i intend to make an evaluation especially the "matching" problem, thus i need an open water characteristics data for the propeller mentioned above.
i've been searching for it and i haven't got it yet. where can i find this data?
please, i need a help here..
thank you very much
Old 06-21-2005, 04:12 PM
RANCHI OTTO's Avatar
RANCHI OTTO RANCHI OTTO is offline
Naval Architect
Rep: 503 Posts: 1,032
Probably the pitch of the propeller is not correct.
I don't know who is the manufacturer but if you send them the sea trial results indicating :
1) speed - rpm - temp exhaust gas - prop. system inclination
they will modify the pitch of the propellers. (is not so complicated)
The openwater of such piercing prop's are more complicated then the open for normal screws because the possibility to trim them.
RANCHI Otto
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
bigger props faster ship? Peter H Boatbuilding 23 02-01-2010 01:08 PM
iges trimmed surface problem in maxsurf hasicktear Software 16 02-13-2006 12:25 PM
Surface piercing propeller characteristics manunk Boat Design 3 06-28-2005 03:12 PM
Analytical propeller theory Guest Boat Design 8 11-12-2003 02:57 PM
