Go Back   Boat Design Forums > Design > Propulsion > Props
Old 05-10-2010, 07:10 AM
conceptia's Avatar
conceptia conceptia is offline
Naval Architect
Rep: 97 Posts: 193
Stern Tube design
I'm doing some case studies, for the enhancement of my design abilities. Can anyone help me how to start with the design of a stern tube. I have the shaft length, propeller diameter, and propeller rpm with me. Would you advise me my starting point and the proceedings like how to find the dimensions of the stern tube.
Also, I would like to know if the stern tube seal has any other function than imparting watertightness to the hull.
Cheers
Aswin
"Aim of any argument or discussion must not be victory, but progress."
Old 05-10-2010, 07:11 AM
conceptia's Avatar
Naval Architect
Rep: 97 Posts: 193
I'd also appreciate if any reading materials is recommended.
Cheers
Aswin
Old 05-10-2010, 12:14 PM
Rep: 1493 Posts: 7,447
The stern tube has to acommodate whatever shaft gland or seal you install. That will determine OD(outside diameter)
Old 05-10-2010, 02:04 PM
Rep: 1758 Posts: 1,561
The stern lines will determine the arrangement, and therefore the length of the stern tube. And yes, the stern tube must do more than just be watertight, and there are classification society rules as well. Mess this up on a large ship and you can easily get into multi-million dollar repairs and possible contract default.
Marine Engineering by SNAME, a whole chapter on shafting and analysis.
Old 05-12-2010, 10:12 PM
conceptia's Avatar
Naval Architect
Rep: 97 Posts: 193
jehardiman, where will I able to find this book Marine Engineering by SNAME.. Is that available in amazon?
Cheers
Aswin
Old 05-13-2010, 02:01 PM
It is from SNAME itself, unless you get it used from a specialist bookseller.
http://www.sname.org/SNAME/SNAME/Home/
FWIW, it pays to join SNAME just to get the member discount on Marine Engineering, Principals of Naval Architecture, Ship Design and Construction, and Submersible Vehicle Systems Design. A professional NA should have all 4 of those references at thier fingertips for questions such as this one.
Old 06-06-2010, 08:16 AM
Andrew K Andrew K is offline
Rep: 10 Posts: 2
Stern tube
Hey guys.
Does somebody know where can i get any stern tube drawings in dwg or dxf??
Thanks
Old 06-08-2010, 10:39 PM
conceptia's Avatar
Naval Architect
Rep: 97 Posts: 193
check in google. The basic drawing is available in the Introduction to Marine Engineering by D A Taylor, and Ship Construction by D J Eyeres.. This have giving the ratio of the thickness and other things of all almost all the members wrt shaft diameter. The only thing you need to worry is of stern tube seals. Of course, for that reason only I'm doing all these calculations.
Cheers
Aswin
Old 06-08-2010, 10:40 PM
conceptia's Avatar
Naval Architect
Rep: 97 Posts: 193
and asking doubts from experts...
Cheers
Aswin
Old 06-08-2010, 10:51 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
if you search the forum , there are dozens of threads on the subject, here is one
shaft bearings ideas please
Old 06-10-2010, 03:46 AM
conceptia's Avatar
Naval Architect
Rep: 97 Posts: 193
Thanks
Cheers
Aswin
RIB hull design and tube attachment jamesdedward Wooden Boat Building and Restoration 13 09-10-2011 02:22 AM
Prop shaft tube, bearings and seal design pdwiley Metal Boat Building 25 12-23-2009 09:22 PM
Loose stern tube zulpas Propulsion 7 09-06-2009 07:31 PM
Long stern tube with dual cutlass bearings? RyanN Inboards 4 10-18-2007 07:16 PM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 07:36 PM
