| small electric motor 140watt, size of prop and speed Hi all. I'm trying to build a small boat, but i'm not to shore of the power requirements. I would like the boat to beable to go over waves. I'm guessing the weight of the boat to be about 5kg - 10kg. The motor that I think might beable to move it out to sea is a 12volt 14amp max at 160rpm and 50kg/cm torque. Hydrodynamics of the boat should be quiet low(if you need I will try to find this info) I would like to hear from you lot weather the motor fitted to a average to good prop would beable to move the boat over the waves. Thanks for you time. |
| Specifications: Input Power Watts: 1,000 Output Power: 480 Watts (Comparable to 3 HP gas outboard) Static Thrust: 68lbs. Battery Output: 400 Watt Hours Integrated Battery: Lithium-Manganese (13Ah@29.6V) Steering Type: Twist tiller Gearing: F-R continuously variable Prop Size: 12" x 10" Weight: 28lb. |
| Specifications: Input power in watts 400 Rated voltage in volts 28.8 Final voltage in volts 33.2 Propulsive power in watts 180 Comparable gas outboards (propulsive power) 1 hp Comparable gas outboards (thrust) 2 hp Maximum overall efficiency in % 45 Static thrust in lbs 33 Total weight in lbs 15.4 Weight of motor without battery in lbs 9.9 Weight of integrated battery in lbs 5.5 Shaft length in inches 17.7 Integrated battery 230 Wh LIMA Propeller dimensions in inches 8 x 8 Propeller speed at full power in rpm max. 1,200 Control Remote throttle control Steering Provision for connection to kayak rudder; lockable Tilting device manual with grounding protection Stepless forward/reverse drive yes |
http://www.youtube.com/watch?v=GJedBprmSkk The motor was working up to 200W in the video to get 11kph. It will do about 8kph with 140W. The motor is a model aircraft motor weighing 59g with a 12:1 reduction spinning a 15 X 12 model aircraft prop. The motor is rated around 600W but would not do that for very long. You should have no trouble achieving planing speed with a 5 to 10kg boat using 140W. 160rpm is quite slow though. A prop pitched to get the speed potential would be unusual for the size of boat. How fast were you hoping to get it up to? Rick W |
| Solomon Technologies - "Electric Wheel" electric motor propulsion systems | lockhughes | Hybrid | 228 | 10-12-2011 04:00 PM |
| High Speed - Low Speed Small Disp Diesels | tranmkp | Diesel Engines | 18 | 02-12-2009 06:21 AM |
| Help! Need high power electric motor for small boats. | SnappingTurtle | Hybrid | 9 | 08-13-2008 02:34 PM |
| How do you determine motor size | lee@simmtechs.c | Propulsion | 6 | 11-22-2005 02:48 PM |
| out board motor well size? | rickc | Boatbuilding | 2 | 06-24-2002 09:23 AM |
