Go Back   Boat Design Forums > Design > Propulsion > Props
Old 05-09-2007, 06:22 PM
harv harv is offline
size & pitch
I am running a 1955 Chris Craft that weighs 1650# and is powered by a new 377" small block Chevrolet motor (400" block with a 350" crank) with appx. 400 HP and is cammed for 6200 RPM. At 6200 RPM I am only at 45 MPH(hand held GPS) with 1-1 ratio.... I now have a 12x13 NYBRIL prop on a 1" shaft , and it is 1" from bottom of boat ....WHAT TO DO ???
Old 05-10-2007, 04:11 AM
Rep: 756 Posts: 3,328
Sounds like the prop slip is way to high . The origonal setup was probably great for 150 to 200hp , maybe. But with doubble the power , youre just warming water with the prop.
A 5 blade night help , but you will probably need to increase the diameter to eat all that power , new shaft strut and all thats involved.
There are sites that figure props on line , yours will be supercavitating.
FF
Old 05-28-2008, 11:34 AM
dmcld77 dmcld77 is offline
Rep: 10 Posts: 4
Pitch way low
I run a 13" x 17" on a similar boat but only have 250hp. You are way low in pitch. I am moving to 19" for an easy cruise of 40 mph at 3000 rpm.
(40 years in boat racing and setup)
Old 06-09-2008, 08:49 AM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
1650# sounds awfully light for a 55 chris craft unless it is a very small (15' or shorter) in which case CG will probably be too far forward causing the boat to "Plow",resulting in very high slippage. If you using a gear box, motor and trans weight alone is 700 - 900 lbs. (depending on how much alum. is used)
Correct Prop for a properly set-up 1650# boat (1850 w. driver and min fuel) is a 11 1/4 dia x 17 pitch. 400hp, turning 6200 rpm providing 90 mph @ 7% slip (55% D.A.R.)
Unless your boat is fairly long > 20 ft.This kind of power and speed usually requires a V- Drive set up to enable CG to be close to transom.
Note: Higher max RPM results in Smaller dia Prop requirements. i.e if Max rpm was (lower) say 5200 with 400 HP, recommended prop would be a 12 1/2 D.. x 20P. providing same top speed. If your boat were not "plowing" or subject to High Drag, current prop dia is addequate & motor would be overreving due to lack of pitch.
Hope this Helps - Jango
Prop pitch & diameter mikey483 Outboards 2 04-25-2007 10:03 PM
OB 2-Stroke 45hp prop pitch & diameter question paularey Outboards 0 01-25-2007 05:44 AM
OB 2-Stroke 45hp prop pitch & diameter question..? paularey Sailboats 0 01-25-2007 05:42 AM
Choosing right quadrant & pitch Maritimo Sailboats 0 01-09-2007 03:23 AM
correct propeller size and pitch for 90 hp tint_champ Props 2 01-07-2007 02:31 PM
