Go Back   Boat Design Forums > Design > Propulsion > Props
Old 09-25-2011, 10:15 PM
Steve K Steve K is offline
RPM limit on props
Is there a limit on RPMs for props, is there a point where they start to "slip"?
I have a 40 thrust lb electric motor on my kayak, measuring my speed by GPS, at full throttle lets say I get 4.5 mph, if I lower the input voltage ( turn down the throttle) I pick up about 1 mph to 5.5
Thanks
Steve
Old 09-26-2011, 01:53 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Not so much an rpm limit but a maximum blade tip speed, so small props can spin faster than big ones before reaching the critical point where a vacuum starts to form and the effective prop diameter decreases. The leading edge shape also plays an important role.
All props slip, but not to the point where increasing rpm result in a lower speed.
In your case you probably need a prop with a better shape and/or smaller diameter.
Old 09-26-2011, 10:47 AM
Rep: 1758 Posts: 1,561
Actually, unless you can see the cavitation, I think what you are seeing is a torque effect.
Props absorb power as torque at a given rpm and prop torque increases the more "slip" you have (actually a lower advance ratio: J = Va/nD) regardless of actual speed. Many motors on the other hand slow down and draw excessive power as you load them up with torque. To prevent overloading the motor, many stock trolling motor props are matched to the motors with flexable blades and excessive sweep. What this does is to twist off the pitch to limit torque when the wheel is heavily loaded. The side effect is that the reduced pitch generates less thrust for a given rpm. Optimiumly, you want to run at a motor rpm and prop slip just below the point that the blades begin to twist off pitch.
If it is cavitation on a stock prop, you might want to inspect the leading edges of the blades. Nicks or ragged edges can cause local cavitation below the back pressure limit which then can then spread to the rest of the blade.
How do you limit amps for charging? Raftman1979 OnBoard Electronics & Controls 78 03-06-2011 02:04 AM
GM and KG limit table xhanasico Stability 5 06-01-2007 02:07 AM
No Limit reached limit Dutch Peter Boat Design 16 09-09-2004 07:20 AM
Next Limit software. Dim Software 2 09-02-2003 02:24 PM
Speed Limit Alert!!! sharkeymarine Open Discussion: All Things Boats & Boating 27 05-08-2003 05:14 AM
