#31
| prop bertram |
#32
| dear Baeckmo i have been sending a picture of prop and shaft a little there after kind regards pascal |
#33
| That doesn't look like the bottom of any 42 Bertram I have ever seen? There is too much shaft between the strut and the prop so that wont help the vibration problem at all. Havign a bolt hanging out of the side of the strut to secure the bearing is not great, maybe a grub screw would be better or none at all depending on the type of bearing that is in there. Do you have a photo of the hull?
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
#34
| bertram or not bertram Here the boat kind regards pascal |
#35
| yep that is one They didnt make the Motor yacht version in OZ so I have no experience with them. It was the keel that I have not seen before?
#36
| Performance is also a factor of how much energy goes into shaft bend/whip rather than thrust. You could try a rigid bearing (I assume you are still using rubber bearings) we have had performance increase reported from users of rigid phenolic composite bearings rather than rubber. Some makes also resist marine growth on the shaft and bearing surface. |
#37
| bearing hello could you said me a little more about those bearing rigid kind regards pascal |
#38
| When you apply thrust to a shaft it will want to bend, it is the bearings that hold it in place or llimit this movement. The closer you can hold the shaft to a straight line position the less energy will be used up in the shaft bending from its centre line as well as corkscrewing as torque is applied. If you use a rigid bearing the shaft canm only move as far as the clearance between shaft and bearing surface. Even when running on a water film the shaft can increase pressure in this film as it starts to bend, this increase in water film pressure will force rubber to give allowing the water film to remaain but the shaft to move. Use a rigid bearing material and the ammount of shaft bend is far less. There are a number of composite bearing manufacturers I work with one make from Perth which I believe performs better than most if not all of the others. Do a search for marine composite bearings and have a read. They are used in quite a wide range of vessels. |
#39
| Rigid Bearing HELLO i WILL SEE IF I CAN FIND SOME OF THOSE HERE IN THAILAND ALL THE BEST KIND REGARDS PASCAL |
#40
| dear typhoon for the hp i am very sure of the 335 hp because i get it out a detroit allison paper with all the details brake hp shaft hp .... if you give me your e mail i will downloard the form and send it to you with everything official i got pictures ... i go actualy 16 knots with very bad thailand made junk propellers of 23 inches thanks for your help if you interested going further send me your e mail kind regards pascal coldefy |
| Propeller shaft torque? | Arnot | Boat Design | 23 | 05-16-2009 05:20 AM |
| propeller to shaft connection | Hisham | Boat Design | 3 | 02-15-2008 11:07 PM |
| Propeller Shaft Bracket | alpamis34 | Boat Design | 2 | 12-20-2006 11:38 AM |
| Propeller shaft stopping for motorsailer | Alik | Boat Design | 1 | 12-22-2004 04:53 AM |
| Bertram 31 Propeller size | utilamayor | Props | 1 | 10-26-2004 03:36 AM |
