Go Back   Boat Design Forums > Design > Propulsion > Props
Old 04-04-2011, 10:47 AM
dcsnowdon dcsnowdon is offline
Rep: 10 Posts: 2
Propeller Selection
Hello,
I am currently working on my own design and build of a Human Powered Hydrofoil. Things are moving along and I am looking into Propeller selection. I am hoping to get a propeller with Pitch ratio in the range of 1-1.4. Through scouring old posts it appears the Bolly 15" x 25" would be a great option.
Does any one know of a good place to order Higher Pitch 2-Bladed Props? OR Bolly Props (I think they are out of business??)
Or
Would I be in better shape building my own prop?
thanks for all your help
-DCSnowdon
Old 04-04-2011, 11:42 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
That depends on whether you get lucky finding the size you're after and if it also has all the characteristics you're looking for. You are likely better off making your own, but to size it (by trial and error) you may want to try some of the model airplane props. Any of that going on in your neighbourhood? It would be great if you could borrow a few to try. Otherwise, Google may be your new best friend. I do know ordering custom sizes is extremely expensive.
-Tom
Old 04-04-2011, 08:11 PM
Rep: 10 Posts: 2
Tom
Thanks. I think you are probably right. I have begun looking at model airplane props. I will try to get a prop with a P/D of 1. I will use this to get the boat going. Then the testing will begin. I might be able to cut the blades at the root...adjust the pitch and make molds. I believe that this process will only be accurate with small changes.
propeller selection hillmaster Props 5 12-09-2008 03:02 PM
Propeller Torque and Propeller efficiency miramon Boat Design 10 07-05-2008 11:36 PM
Propeller Selection hasani Open Discussion: All Things Boats & Boating 6 04-19-2008 03:20 PM
propeller selection gharai Jet Drives 1 12-22-2007 04:02 PM
Prop Selection CMARSHALL Props 3 07-03-2006 04:44 AM
