Go Back   Boat Design Forums > Design > Propulsion > Props
Old 06-16-2008, 04:33 AM
dtoshni dtoshni is offline
Rep: 10 Posts: 40
Propeller Efficiency: Ducted Propellers
Hey there!
Can you please help me out. I need to find out how to calculate the efficiency of a ducted propeller for the light weight vehicle I'm building. If you can please post a method of hoe to do this, it'd be great. And also I seem to have lost my PNA. I think it has a section regarding this. If someone can please post the images of the section, I'd be really grateful to the person.
Thanks.
Daniel T
Old 06-16-2008, 05:19 AM
Previous Member
Rep: 0 Posts: 0
With JavaProp:
http://colaco.freeshell.org/mhepperl.../jp_applet.htm
you simply tick the "shrouded rotor" tick box on the design page. I have attached an example showing shrouded and unshrouded.
A shrouded prop reduces the losses to induced drag. If you have a heavily loaded prop with low aspects blades then shrouding makes a difference. As the blade aspect increases and loading is reduced the advantage of shrouding is reduced.
Rick W,
Propeller Efficiency: Ducted Propellers-picture-12.png  Propeller Efficiency: Ducted Propellers-picture-13.png
Old 06-16-2008, 05:51 AM
Rep: 10 Posts: 40
Thanks a lot Rick.
Can you please just help me out a little more. I need to know what the spinner dia. dsp. is?
Old 06-16-2008, 06:10 AM
Previous Member
Rep: 0 Posts: 0
Originally Posted by dtoshni View Post
Thanks a lot Rick.
This is normally the prop hub diameter. Spinners are fairing pieces that promote streamline flow over and behind the hub. With a boat there is rarely a nose spinner but often a tail cone:
http://www.propellerpages.com/conten..._prop_back.jpg
simply ensures streamline flow to reduce drag.
Attached image shows a small diameter faired hub with both nose cone and and tail cone. These reduce the prop losses and are assumed to be installed for using Javaprop.
Rick W.
Propeller Efficiency: Ducted Propellers-faired_hub.jpg
Old 06-16-2008, 06:17 AM
Rep: 10 Posts: 40
Thank you Rick.
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 04:10 PM
Calculating propeller efficiency and Cleavers Joakim Propulsion 8 06-01-2007 08:40 AM
Ducted Propeller on Retractable Outboard for Sailing Yacht ? Seabury Propulsion 6 11-22-2006 12:38 AM
The Most Efficiency Electromagnetic Propeller waveless Boat Design 4 08-22-2005 07:08 AM
Propeller Efficiency fredrosse Boat Design 3 03-16-2005 08:10 PM
