| propeller design Hi everyone, Ive been working on this project for 40m crewboat vessel. The situation is as follows: Vessel spec: L=40m, B=7.2m, T=1.75m Design point: 21knots at 180tonn displacement. The vessel has a restricted propeller diameter of 1.1m due to hull clearance. So to produced the required speed, 3 propeller were necessary. Unfortunately, the gearbox ratio chosen cannot be altered due to space constrictions and a gearbox ratio of 2.95 was already chosen. Also, the vessel will have 3 engines producing 1400bhp at 2300rpm. To make the propulsion unit more efficient, the shaft angle was increase from 8 to 10 degrees in order to accomodate a larger propeller; and now it is possible to fit a 1.35 m diameter propeller. I would be interested to hear any comment and suggestions and also if possible, some calculation on expected operating rpm, BAR and pitch ratio to compare with my results. I have found that for 4 bladed 1.35m diameter: BAR=0.85, P/D=1.005, at an rpm of 530. I have been using Autopwr program. Any suggestions regarding a good propeller design program for personal use at a reasonable price. thanx. |
| First of all, how did you arrive at 530 shaft rpm? In my book 2300/2.95=779.7! That is the primary dimensioning rpm. Your Froude nr (by volume) is 1.4 and she has a slenderness ratio of ~6.5 depending on WL length. This means that there should be no hump to worry about, the top speed is actually head-on the little hump there is. All provided there are no special "tricks" in hull design. In this case propellers must primarily be selected to satisfy either of two basic conditions: A/ Max power-max speed, B/ Cruising condition, added resistance due to weather conditions, allowable continuous power output. I guess your speed estimate of 21 knots is referring to condition "A"? What's cond "B" like? Last edited by baeckmo : 11-03-2009 at 09:51 AM. Reason: typo |
| thanks for your reply baeckmo. The design is basically a conversion of a previous vessel. The previous designer had opted for a gearbox ratio before specifying the propeller rpm! When i looked at the design, i thought that to get the best out of our propeller, we would need a bigger gearbox ratio; however such a procedure would not be possible due to space restriction on the vessel which would not enable it to accomodate a bigger gearbox. Condition B is 130ton displacement at 25knot. |
| Wouldnt "B" be below "A" in terms of speed and heavier in terms of displacement? Just reading the post here I would guess the speed for "B" to be in the 18 knot area but not sure what the displacement would be (add passengers, fuel, stores, etc) |
| You misunderstood baeckmo. Condition B is at the same displacement, but continous (always lower) speed. And gearbox dimension is not necessarily related to ratio! The ratio can be choosen within a certain range in the same housing! Regards Richard |
| propeller Here is our results * 4 Bladed Wageningen B Diameter 49.00 inç Pitch 48.00 inç Dar = % 80.74 Speed = 26.00 knot Price MnAlBrz 7450 Euro * 4 Bladed Master Diameter 45.81 inç Pitch 47.00 inç Dar = % 95.07 Speed = 26.00 knot Price MnAlBrz 7580 Euro Oktay Çemberci istanbul/turkey oktay@cembercidenizcilik.com |
| hey navarch, just download and try the latest version of freeship @ freeship-plus.land.ru
__________________ "There is a great value in disaster-we can start all over again." |
| Propeller design | skipper_rj | Props | 21 | 05-07-2008 09:07 AM |
| Propeller Design Software | davidmarine | Software | 6 | 12-29-2007 09:04 AM |
| propeller design | vpkumar | Props | 3 | 09-25-2006 10:54 AM |
| Propeller Design Charts | design.ho | Props | 8 | 04-18-2006 03:57 AM |
| propeller design parameters | fcfc | Props | 2 | 09-16-2004 09:49 AM |
