| Propeller design I am not used to design of propeller for planning boats, and I would like to learn more about it. Does anybody have a hint of a book or an article that I could read, in order to know more about it? I would specially like to know more about propeller/hull and motor optimization. Thank you. |
| Use this site to determine the hull drag: http://illustrations.marin.ntnu.no/h...ing/index.html Use this site to determine the best prop: http://colaco.freeshell.org/mhepperl.../jp_applet.htm You have to set Options pagto suit water. If you can use these two sites you will be close to the required design. The "optimum" will depend on the constraints and practical realities about strength of materials, draft etc. Rick W. |
| Thank you Mr Rick, I had some difficulties to use the page because of the java app required, but now it is ok. I am a bit affraid of using ready to use algoritms, specially because I haven´t yet found any that fit to calculating resistance of powered catamarans. Do you think this should work well? Thank you again. |
| skipper_rj - you're right about the uniqueness of powered catamarans. There is a need for analysis of the balance of planing loads of different surfaces combined with the issues of dynamic stability changes through the velocity range. It's certainly all possible, however, event though mathematically complex. Have a look at the "Secrets of Tunnel Boat Design" book and the "Tunnel Boat Design Program" software - both specifically dedicated to detailed analysis of lift/drag/power characteristics of powered catamarans.
__________________ /Jimboat AeroMarine Research 'Secrets of Tunnel Boat Design' book 'History of Tunnel Boat Design' book 'Secrets of Propeller Design' book 'Tunnel Boat Design' software w/'Vee hull design' & 'Porpoise Analysis' 'PropWorks2' software 'Vee Hull & Vee Pad Design" paper 'BoatDesign.net article on Tunnel Boat Design" |
Rick W. |
| Thank you again Mr Rick. |
| catamaran design Quote:
| how do you figure the lcg i know it was 8 ft from the transom when i buit it and then the vcg at my thickest point or side view its only 26 inches ???
__________________ http://allfiberglassrepairs.com/index.php |
| now im really lost Quote:
thats going to take some time for me to get the hang of that
Rick W. |
Torque and fuel effiency Rick W. |
The important issue to recognize is that the Dynamic CofG changes at each velocity. So it's important to check the Dynamic CofG throughout your operating velocity range. Balancing the hull on the trailer is really only of value if you intend to run your boat while it's on the trailer. There are methods of establishing the dynamic CofG. Here's an article that I wrote that touches on methods for considering dynamic center of gravity (center of dynamic balance) for typical power catamarans.
No need to make it more complex than needed to get a good answer. Note: The linked Savitsky model scale only goes to 45kts. Even at this speed other factors come into play so it is of limited value at the high end. Rick W. |
| jim i coundnt read it the letters were fuzzy ill try to blow it up now as i sit in the water how do i find my lcg i know i need more lift about a ft from the transom i was thinking of a 1 1/2 inch step about a foot from the end of my transome step or making a small shallow tunnel just in behind the sponsons but under and on the outside of the after plane i could catch some air and drive it under my transome and out the back of the hull but im not sure i would get the lift i need
| propeller design charts | vpkumar | Props | 1 | 10-03-2007 03:19 PM |
| propeller design | vpkumar | Props | 3 | 09-25-2006 10:54 AM |
| Propeller Design Charts | design.ho | Props | 8 | 04-18-2006 03:57 AM |
| i NEED YOUR HELP IN DESIGN PROPELLER IN NOZZEL ! | mymind04 | Boat Design | 3 | 01-28-2006 01:55 PM |
| propeller design parameters | fcfc | Props | 2 | 09-16-2004 09:49 AM |
