Go Back   Boat Design Forums > Design > Propulsion > Props
Old 05-13-2012, 02:03 AM
A_Appleyard's Avatar
A_Appleyard A_Appleyard is offline
Rep: 10 Posts: 16
Propeller blades turning
I am sorry to appear silly, but have any of you heard of a ship or boat or submarine propeller where each blade can rotate on its support and back each time the propeller turns, like the blades of a helicopter's rotor? That would seem to let the propeller make sideways propulsion.
http://en.wikipedia.org/wiki/Helicopter_rotor
Old 05-13-2012, 09:46 AM
SheetWise's Avatar
SheetWise SheetWise is offline
All Beach -- No Water.
Rep: 658 Posts: 293
I wouldn't think there's enough leverage given the relatively small diameter -- one side pushing and one side pulling would just stress the shaft.
Time is Gods way to keep everything from happening at once.
Old 05-14-2012, 12:43 AM
DCockey DCockey is offline
Engineer
Rep: 1337 Posts: 2,369
Interesting idea and in theory a sideways thrust would be developed but it may not be much.
Keep in mind that helicopters move sideways by the helicopter tilting so that the lift vector of the main rotor has a component in the desired direction of motion. The cyclic variation in main rotor blade pitch and therefore lift causes a moment which causes the helicopeter to tilt.
David Cockey
Old 05-14-2012, 02:50 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 1074 Posts: 702
Actually, there was a prototype tug (?) built (or maybe only projected) on this principle a couple of years ago, in order to evaluate the principle. If I recall correctly it was patented, but as far as I know it did not "make it to the market".
Old 05-14-2012, 03:23 AM
liki liki is offline
Rep: 114 Posts: 208
There exists Voith Schneider propulsion already: http://en.wikipedia.org/wiki/Voith_Schneider_Propeller
Old 05-14-2012, 05:05 AM
Frosty Frosty is offline
Previous Member
Rep: 0 Posts: 0
Of course there is variable pitch props. The maxi prop is one.
Most ships and especially tugs have them with no gearbox, all done on pitch adjustment.
Old 05-14-2012, 10:25 AM
Hydrodynamics
Nope, Frosty and liki, this is a "conventional", horizontal shaft CP prop where the pitch can be varied individually around the perimeter sectors. Looking from aft for instance, the port sector of the propeller disc may have maximum forwd pitch, while the starboard sector simultaneously is given zero pitch. This will produce a longitudinal turning moment, due to the asymmetrical propeller loading, as if there were a rudder in stbd position.
The effekt, of course is similar (but not identical) to the operation of VS vertical shaft propeller, with the higher propulsion efficiency of the horizontal shaft prop, but with a reduced manoeuvering capacity compared to the VS prop.
Old 05-14-2012, 10:51 AM
Previous Member
Rep: 0 Posts: 0
Yup there is those too. I forget the name of the drive -I think they had problems and went. It was a Uk company. Its on the forum somewhere with VDO of its maneuverability.
Bandsaw blades for frp tunnels Fiberglass and Composite Boat Building 9 12-08-2011 11:40 AM
number of blades vs vibration, efficiency, cost Tongichi Props 2 07-25-2011 06:45 AM
Are guide blades better than a bulbous bow? ivor Bittle Boat Design 21 03-27-2008 09:47 AM
2 blades propeller Hisham Boat Design 3 01-31-2008 07:57 PM
2 blades pedal propeller Hisham Props 1 01-23-2008 06:11 AM
