Go Back   Boat Design Forums > Design > Propulsion > Props
Old 11-11-2009, 07:12 AM
Rep: 1397 Posts: 7,215
Prop in a tube
The minimal version would be a Kort nozzle and the other extreme is a thruster in a long tube. How many variations of this setup are there?
Old 11-11-2009, 02:19 PM
Mariner
Rep: 777 Posts: 1,543
147.
I have no idea how many variations there are but don't forget all the jet
drives out there!
Tom
Old 11-11-2009, 02:20 PM
I was thinking of a prop not an impeller.
Old 11-11-2009, 02:24 PM
Mariner
So, KURTZ, RICE, the standard outboard prop protectors, bow thrusters...
Why do you ask, gonzo?
Tom
Old 11-11-2009, 02:29 PM
Just curious about weird variations
Old 11-11-2009, 02:34 PM
Mariner
Curiousity's good.
Do jet turbines count?
They're in a tube.
I guess not, they're not props...
Old 11-11-2009, 03:10 PM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 909 Posts: 597
Tom, do you really mean turbines? Per definition a turbine is a device extracting mechanical energy (mostly shaft power) from a fluid flow, while a pump (equals propeller and impeller) is transferring mechanical energy to a fluid. Gonzo started with a quest on the later kind of machinery. Sorry to rain on your parade, but as a turbomachinery research engineer, this distinction is a soft spot to me.....
Old 11-11-2009, 04:15 PM
I think I need to set some rules. No peeing in this thread
Old 11-11-2009, 04:43 PM
Hydrodynamics
Rep: 909 Posts: 597
Ok Gonzo, changed fluid.........
Old 11-11-2009, 05:29 PM
Mariner
baeckmo,
I really did mean turbine as gonzo didn't stipulate the fluid be water.
I should have clarified I was thinking of an aircraft style jet.
But it's still not a prop, so no matter, but thanks for asking.
Tom
airflow in a tube dreamer Boat Design 4 03-23-2009 07:13 PM
How to calculate the pressures produced by a prop in a tube? RipSlider Propulsion 0 07-28-2008 08:05 PM
lumpy FG tube help tsmwebb Fiberglass and Composite Boat Building 7 05-24-2007 01:45 PM
aluminum tube eurotk1 Metal Boat Building 2 12-27-2004 09:47 PM
Flotation Tube nightz13 Boat Design 1 09-14-2004 10:10 AM
