| Prop Thrust Calculation I'm making a long tail outboard motor using a diesel engine and I'm trying to determine roughly the thrust the prop will be generating. Any help would be greatly appreciated. The prop is a 7.75" diameter, 6" pitch prop (cupped). The engine is turns at 3600rpm max. The boat it will be pushing will be a metal boat shaped like a dugout canoe and I'm guessing it will travel at 8-10mph. The reason this is important is I'm considering connecting the long drive shaft (which will have the prop on the far end) directly to the crankshaft of the motor which will impart the thrust generated by the propeller to the crankshaft of the motor. The motor is rated to take 287.7 LBS of axial thrust. That's the magic number. If my prop is going to generator less than 287.7 LBS of thrust I can skip the thrust bearing. I've seen photos of motors that are the same general design as what I'm building, they take any old motor and slap a drive shaft and prop on it, and it appears without any additional external thrust bearing. It appears they let the engine's crank shaft take the thrust. Any input you could give me would be greatly appreciated. I'd like to know how much thrust the prop would develop as well as anyone's thoughts about applying the thrust directly the engine's crankshaft is a good or bad idea. Thanks! You can see the motor at http://gregihnen.me, then under about me and my motor. Greg Ihnen |
| The thrust developed against the shaft depends on the resistance of the hull.
__________________ Gonzo |
![]() Consider these two cases, for example: - an accelerating boat, when the prop thrust is higher than boats' resistance, the difference being necessary to overcome the inertial force - the bollard pull, when the boat is standing still yet the prop is pushing hard. Cheers |
If you think you'll need to do more such calculations in future, and/or have them more precise, I suggest you to buy the excellent Dave Gerr's book "The Propeller Handbook". You can find it at Amazon for $12, a real bargain for the knowledge it contains: http://www.amazon.com/gp/offer-listi...condition=used Cheers! |
| Accelerating fast (hole shot) is a function of the mass of the boat more than anything else. However, that would be of short duration.
Knowing that boats I will run this motor on with a 15 hp will do around 14 mph I'm assuming I'll be shy of that, maybe around 10 mph. so I'm going to use that in my calculations as a starting point. Now as I understand it that formula only good for when the boat is underway otherwise you get a divide-by-zero error. There's a separate calculation for "bollard pull" thrust. Would you recommend I calculate that too so I know the thrust from a hole shot? Or should I just refrain from pulling bollards. : - ) Greg |
I ran the calcs at 8 mph and 10 mph and the thrust was fine. Well below what the motor will tolerate. But, I'm betting the farm on that .5 prop efficiency. If that's not in the ballpark, that's to say if the efficiency is much higher, then my motor could be toast. Are you pretty sure of that one? I just have to ask, strawberry, pineapple or banana? Greg |
![]() Quote:
T = 11.87 * ( SHP * D )^0.67 where: - T is the bollard pull, in pounds - SHP is the engine shaft horse power (calculate it as brake horse power, BHP, times 0.96) - D is the propeller's diameter in inches. - ^0.67 means "elevated to 0.67th power". And yes, it would be wise indeed not to waste your fuel for pulling stupid bollards... ![]() Cheers! |
Thanks so much! I really appreciate the help! I wish I could buy you a daiquiri! Greg |
One more thing. Don't make a confusion between mph and knots. Mph means "statute miles per hour", while a knot is "nautical mile per hour". 1 knot = 1.15 mph. I knew it would happen, sooner or later... ![]() |
Yeah, I caught that but thanks for pointing it out. I did the mph to knots conversion on my Mac's dashboard widget. Thanks so much! I greatly appreciate everyone's comments, thoughts and time. Greg |
| You are getting great advice from daiquiri
| Propeller thrust I strongly recommend getting a copy of "The propeller handbook", it is a suprisingly interesting read even if you don't wan to do the maths. |
| A simple rule of thumb is a good prop will make 20 lbs of thrust per hp. Sure in theory it can be higher , but 20 works. Use your engine rated power , 10HP x 20 would be 200 lbs thrust. That work for you? FF |
| How To Hull Thrust/Drag/Friction Calculation from AutoCAD Model? | Shafri | Software | 7 | 11-25-2010 07:20 AM |
| Prop sizing and thrust | jonr | Propulsion | 24 | 05-06-2010 04:18 AM |
| Which prop is right for my 25 Lb thrust Trolling motor | thudpucker | Outboards | 5 | 07-21-2009 01:07 AM |
| Determining prop thrust | YuriB | Inboards | 3 | 09-29-2008 08:08 AM |
| Prop Thrust Calcs / Bow Thrusters | jocko_nc | Boat Design | 0 | 04-20-2004 06:32 PM |
