Go Back   Boat Design Forums > Design > Propulsion > Props
Old 09-18-2011, 10:33 PM
FMS FMS is offline
Rep: 125 Posts: 233
prop striations?
What purpose do the striations serve on this prop:
http://www.boatdesign.net/gallery/sh...hp/photo/20171
Old 09-19-2011, 02:41 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 962 Posts: 631
What you see is milling traces. Since the tool leaves circular traces when moving along the prescribed track, light is reflected differently along those tracks. This can be particularly obvious if looking at the "rough cuts", before the finishing steps are completed.
Old 09-19-2011, 10:53 AM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Looks like more than milling traces to me. If you look at the base of each blade, you can clearly see how the striations come to a defined stop. The size and spacing is identical on each blade, and they throw shadows.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 09-19-2011, 11:25 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Looks like grooves from initial, coarse milling with a large diameter ball cutter to me. Probably done with a CNC mill. Additional, finer milling would follow with a smaller diameter cutter, probably several more stages of milling.
Old 09-19-2011, 11:57 AM
Rep: 1758 Posts: 1,561
Yep, first pass and then you stress relieve again. Otherwise the blade will walk on you.
Old 09-21-2011, 07:23 PM
FMS FMS is offline
Rep: 125 Posts: 233
Thank you all. I have never seen a prop of this scale being milled. I also saw the depth and stairstep of the shadow closer to the hub and thought maybe someone was reinventing the wheel. Thank you all for clearing that up for me.
The Right prop.... petrey10 Sterndrives 11 07-02-2007 05:43 PM
What prop? Poppajoe Props 3 04-19-2007 12:46 PM
Towing a prop -- how to pick a prop? Eric! Props 28 10-06-2006 02:09 PM
prop robbie Outboards 0 08-20-2006 05:36 PM
What prop next? Poppajoe Sterndrives 6 07-07-2006 11:17 AM
