| prop power curve Can someone share a curve for a 24" diameter, 19p 3 blade prop? I had one - cannot find it. Want to plot it with my FL T160 engine driving through a 1.9 ratio Velvet Drive tranny. Also a 26" diameter 4 blade (higher DAR) - same pitch. Thanks! Jim |
| The manufacturer can give it to you. There are many variables, like rake, section type, thickness of blades, cup, etc.
__________________ Gonzo |
| I do not have the manufacturer - no markings except diameter and pitch. No rake, minimal sweep, nibral (thin), no cup, three blades. A nominal one will be a big help |
| Props are like tires. You can't answer what does a 15' tire specs are. Try http://www.miwheel.com/
| Cat power and prop calcs | dboatsafrica | Multihulls | 0 | 05-18-2008 03:46 AM |
| Prop absorb vs power | bit | Props | 1 | 02-15-2008 01:05 PM |
| Power And Prop Selection For Hard-chine High Speed Planing Crafts | yades | Boat Design | 9 | 02-13-2008 05:00 PM |
| GZ curve | genesis-uno | Stability | 2 | 06-19-2007 09:21 AM |
| Prop power curve | Deering | Propulsion | 6 | 12-14-2005 10:03 AM |
