| prop pitch I just bought my first inboard I have always had outboards. The boat that i bought was a cruiser cut down and made a workboat it has a 318 chry gas 4 barrell engine it is 34ft 10 ft beam it is a wood boat, dont know the rpms the guy did not have a tach in it I am giong to put one in it. I have the boat in dry dock now the prop is 15 -12. I could only get 11-12 knots out of it. Would a higher pitch get me any more speed or would it kill the engine.I can not put a taller prop because of room. It has a 1-1 trans.If the prop wont help other than putting a bigger engine in it, is there anything else I could do to pick up a few extra knotts |
| Pitch Calculation Dear ems Please kindly fill the '' propeller sizing form '' on www.erispropellers.com .I will calculate the pitch and reply you immediately . |
| You are limited because of propeller space. You need more propeller surface area, which in your case, can only be obtained with additional Blades. Also the 1 :1 trans necessitates a very low pitch which is less efficient. Either a 4 or Preferably a 5 blade, 15 x 9 or less pitch should get you a few more knots with your present setup. I suspect your current pitch (12) is already choking the motor and lack of blade area is causing huge slippage. |
| OB 2-Stroke 45hp prop pitch & diameter question | paularey | Outboards | 0 | 01-25-2007 06:44 AM |
| prop pitch bmeasurements | spike | Props | 1 | 12-31-2004 11:03 AM |
| now do i measure prop pitch | gkelly | Props | 1 | 09-12-2004 05:58 AM |
| Drive Ratio and Prop Pitch | rayjay | Powerboats | 3 | 04-22-2004 03:07 PM |
| Need Info On Prop Pitch | Delta Explorer | Powerboats | 0 | 07-07-2002 09:48 AM |
