Go Back   Boat Design Forums > Design > Propulsion > Props
Old 11-12-2011, 01:33 PM
Gered Gered is offline
Rep: 10 Posts: 3
Prop mounting with using a safety, cut-off pin on outboards - propose to discuss
Hi all. I apologize in advance for my english
Prop mounting with a safety pin in present time is used on some small power outboards (up to 6-8hp). Previously, 20-25 years ago, such prop mount is widely used on outboards up to 30-40hp and more, as I remember. This mount has some advantages.
Minimal risk of damage to the blades and, more importantly, the motor gear. Also, this mount has its drawbacks - often uncomfortable process of replacing the prop and cuted pin.
With the increasing power of outboards and using exhaust through the prop the prop fastening on a shaft became splined connection.
Splined connection is more simple and convenient to install the prop. But at the stroke risk of damage to the propeller blade and gear box is very high.
What do you think about the reasons why now is not used fastening screws using a safety pin?
Is this structural complexity in the case of exhaust through the propeller?
Is this additional income to producers for the sale of spare parts and screws?
And second, how this situation (prop mounting with the splined connection) explain by the representatives of the manufacturer? – May be someone knew, heard or read their opinion on this issue?
Thanks in advance for your opinion
Old 11-13-2011, 01:23 AM
FMS FMS is offline
Rep: 125 Posts: 233
If you hit things regularly I can see the advantage of a pin which can be replaced far from home. The pin is cheap, but if it breaks the prop will likely be damaged anyway, so...
I haven't spun the rubber hub in my prop once in the last 10 years, so I like the ease of taking the prop on and off without needing a pin.
Old 11-13-2011, 08:06 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
The nice thing about rubber hubs (that replaced shear pins on most outboards and sterndrives) is that, after hitting something, they re-engage. So you can often still limp home at idle with a bent blade, whereas a shear pin would leave the prop free-wheeling.
I've seen plenty of rubber-hub props damaged, up to ~200 hp. I've yet to see a shaft or gearbox break as a result of banging such a prop.
Old 12-14-2011, 06:49 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
and
many companies offer user replacable rubber hubs
The pin had to go away on big engines as it removes the solid conection which is very tough on the shift dog with an aluminium prop and horrendous with a stainless prop
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 12-15-2011, 02:10 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
There are no commercial reasons for the widespread use of rubber hubs, only mechanical ones.
The shear pin concentrates the torque load on two small areas, limiting this construction to small engines only because using a larger pin diameter requires a larger hole, weakening the shaft at that point. A splined shaft can handle a much higher torque, so a smaller diameter can be used without the risk of deformation.
And of course the use of rubber to transmit torque to the prop is much more gear friendly than a metal pin.
Old 12-19-2011, 04:16 AM
Rep: 10 Posts: 3
Originally Posted by FMS View Post
... The pin is cheap, but if it breaks the prop will likely be damaged anyway, so...
The prop with pin can be demaged as rule in high roration speed and solid obstacle - but this does not necessarily and depends of many conditions.
Your situation doesn't need the pin, but it can be very different.
Old 12-19-2011, 05:11 AM
Rep: 10 Posts: 3
But if "something" is enoth solid and big you 'll get geabox crash - I"ll prefer to replace the pin or prop.
I know situations when the geabox was breaked, but prop and blades are ok, with outboards 30-70 hp.
support for mounting outboards autobahnbuyer Propulsion 2 02-12-2010 12:42 PM
Stringer replacement...noob, please discuss options with me...been reading alot Sprint18 Boat Design 19 05-29-2009 07:46 PM
Where should we discuss onboard computers? TerryKing Forum Questions and Suggestions 17 03-16-2007 10:30 AM
HullDrag/32 revisited - invitation to propose extensions h_zwakenberg Software 0 11-05-2005 01:42 PM
Soft mounting of outboards Palmer Boat Design 0 03-20-2004 01:32 PM
