| Prop efficiency curves Does anyone have or know where to get prop efficiency curves for surface piercing props? Have any tests been done on them? Thanks |
| There is some data in this paper: http://www.icmrt07.unina.it/Proceedings/Papers/c/44.pdf If you google arneson or other surface drive manufacturers you will also find some curves. The peak efficiency I have seen in any of the data is 70%. Well below what can be achieved with a fully submerged prop or air prop but these have certain limitations. Rick W |
| These data seem to be quite confidential and I have been searching for quite a long time. The only documents I was able to find are a test protocol by Rolla, a paper by Marco Ferrandi, Stefano Crotti, and Michele Viviani (which contains some handy regression formulae to produce KT/KQ/η curves; I made little Excel spreadsheet of this), and finally a product leaflet by France Hélices where there are two little diagrams of unspecified surface piercing propellers. However, this seems to be no longer online. Edit: Oops, Rick was quicker... ![]()
__________________ All the best, Olav GER-1045 ____/)_/)/)___ |
| Power curve, the sub http://zone.sousmarins.free.fr/zone%...%20helices.htm yes i know this is french but take a look at pictures at the end...can use translator too. they say water is also pressure injected close inside the fairing to improve flow i wonder what would be the efficiency of this twin pump prop with fairing around ? 0.9 region, ? And what would give an approximate home made copy of such a propeller pump ? Less but certainly a lot anyway, it would be worth trying A pump jet with 2 propellers can be seen on some jet ski, should we get inspired ? |
| the jetskis are all single impeller with a stator behind it, as are most of the jetdrives currently being made. |
| Jet vs. Prop Efficiency | Michael1 | Jet Drives | 29 | 11-19-2011 07:29 AM |
| Diesel Efficiency vs. Gas Efficiency | Northwester | Diesel Engines | 23 | 02-14-2009 03:49 PM |
| Rhino Curves | jmedick | Software | 6 | 06-27-2007 01:34 PM |
| Prop efficiency? | MagicMike | Outboards | 7 | 10-02-2006 07:49 AM |
| Prop Efficiency in Reverse | phillip | Props | 3 | 05-01-2005 10:36 AM |
