| Prop absorb vs power One question. The power absorbed by the propeller is: Diameter^4 x Pitch x Rpm^3 x 1.3 / 1E +14 ? Example: Propeller 23" x 14" 1500 RPM = 172 hp 1050 RPM = 59 hp 600 RPM = 11 hp The calculations are correct? Thank you, Bit |
| No. Power absorbed is a function of torque and rpm. Torque is a function pitch, diameter, rpm, and speed of advance. Therefor your equation cannot be correct, though it may be a curve fit of some specific data. See the following lecture notes. http://ocw.mit.edu/NR/rdonlyres/D5F2...eller_test.pdf
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Power And Prop Selection For Hard-chine High Speed Planing Crafts | yades | Boat Design | 9 | 02-13-2008 04:00 PM |
| The Right prop.... | petrey10 | Sterndrives | 11 | 07-02-2007 05:43 PM |
| Towing a prop -- how to pick a prop? | Eric! | Props | 28 | 10-06-2006 02:09 PM |
| Prop power curve | Deering | Propulsion | 6 | 12-14-2005 09:03 AM |
| Sail power and horse power? | kjell | Motorsailers | 12 | 09-03-2005 03:20 AM |
