#121
| So that prop is an E192 all the way from the hub to the tip? But it is thicker towards the hub, meaning the chord ratio would change towards the hub? As far as the edge shape is concerned is it mostly an ellipse with the leading edge a little exaggerated?
__________________ Wake me up if we hit something. And you guys can Call me Joe |
#122
The Single Analysis page of JavaProp displays the Re# at various radial positions if you want to check your selection. My automatic optimisation will usually give an efficiency 1 to 2% higher than a first pass at JavaProp but you can also play with the values in JavaProp to gradually improve the result. The problem is that the end result with JavaProp will have an error of the order of 1 to 2% due to the variation in Re# so you really cannot be certain that the improvements shown will be actually achieved. As you can see the potential for error from JavaProp is quite small unless you use Re# that are way out but I am chasing every little bit I can get so am interested in narrowing small errors. Rick W |
#123
#124
| I do not use JavaProp for my own designs. I want greater precision and more control on wider range of parameters than it can give. I also check for and allow for cavitation but am not interested in compressibility issues. Rick W |
#125
In all design work it is imperative to clearly define objectives, and to know when something is within the tolerances. As we learned earlier, at 2 knots, the power consumption should be less than 30 watts; or about 25% of the total energy requirements, including on board computers and other equipment, making a 1 to 2% savings in propulsion is only a .25 to .5% savings on the total system. How much work should be done to try to save that much power? Something else has occurred to me as well. What do you think about starting a tread (or maybe there is one already that could be revisited) about all of the mathematical terms used in fluid dynamics and an explanation of them that lay folks, like me, could understand and even some calculations that would work in spread sheets.
#126
![]() How about you putting down questions about specific things that puzzle you and the rest of us trying to give simple answers? |
#127
Rick W |
#128
| I totally get it when you are talking people power and world records. One of our local museums has one of the early people powered airplanes, it actually might be the first one. With a 90 foot or so wingspan made out of stretched plastic bag material. Every ounce accounted for, as much lift and as little drag as possible.
#129
| Well I think I’m going to purchase a plastic model airplane prop, $24.95; and if it’s not strong enough or thick enough. I’ll take some measurements, add some West System Epoxy 105 filled with 410 Microlight, sand it off with a random orbital sander, throw it in some sand, and make an aluminum casting. Next I’ll break out the random orbital sander again and make it smooth. Hopefully that solves that problem. Once again thanks for all your help guys and especially Rick. Other harder questions are coming soon.
#130
| Any idea about how much % increase in power requirement between the first nacelle and the second?
#131
| Proportion drag to the ratio of Volume to ^ (2/3). Rick W |
#132
| Thanks Rick, It looks like we might be in one of those fuzzy areas where linear functions fall a little short. I must assume that the formula ^(2/3) works for scaling object of identical shapes, and does not account for hydrodynamic forces due to variations in flow. For example the second nacelle has an L/W ratio of roughly 4 to 1 and the first is 6 to 1. What effect will that have? It would seem (intuition again?) that the actual increase in drag would be more than is indicated by, ^(2/3). How do I account for that part?
#133
| Go back a few posts and see what you said there about precision with estimates. Until you get below fineness ratio of 3 I doubt that you are doing more than "polishing the turd" to use anything but the drag ratio based on volume as I suggested. Rick W |
#134
Joakim |
| Defining required engine power and gearbox ratio | marineengineer | Props | 12 | 12-13-2009 06:56 AM |
| Power Foils-added power to carry sail... | Doug Lord | Sailboats | 33 | 08-18-2009 10:35 PM |
| Power/Resistance Calculation for Planing V-Hull & Fuel/Engine Required | Kapitan_Raider | Outboards | 24 | 11-26-2008 05:34 AM |
| How do you calculate the power required for propulsion? | slipshot | Propulsion | 3 | 08-19-2008 09:28 AM |
| How much power is required? | bxbbuddy | Outboards | 1 | 12-19-2007 02:50 AM |
