#106
The power estimate I provided relates to an open water prop of 300mm diameter. If you go to little jets you will at least double the power required. This video shows what 200W can do on a 120kg boat using a 15" open water prop. Drag at 10kph is around 50N, similar to what you would have with a streamline 40kg hull at 8kts (no ports or ducts) but rudder and elevator. The motor is a PMSM weighing 59g and is geared 12:1. http://www.boatdesign.net/gallery/da...11JE_10kph.wmv If you are going to use small ducted props then the 500W I gave you for the 30mm prop will be more like it; providing you can set the ducts up not to interfere too much with flow and add extra drag. Rick W |
#107
It was a typo on the 25 mm I always thought 12 inch props. We did some work on props a while ago and discovered long narrow make for better efficiency. My intension is to use large props with ducts. Now if it turns out that all they do is keep fishing nets out of the props, then I guess that's what they'll do.
__________________ Wake me up if we hit something. And you guys can Call me Joe |
#108
You should think of ducting solely as a guard and maybe steering if you want to avoid the rudders and elevators. Keep as thin as possible consistent with protecting the prop and taper the leading and trailing edges to reduce drag. The most effective sudden stop mode using a prop will be achieved by slowing the prop to avoid the blades stalling. This will be far more effective than going hard astern. Large ships use the helm to effect a crash stop as the turning absorbs a lot of the energy. Rick W |
#109
I totally agree; we have complete control over motor speeds and applied torque. The mechanical systems are all 100% integrated with the on board computers. So we can do testing and find out exactly how much negative power to apply or to create an exact come to stop routine, within the power range of the motor. They sample at 2.5mz and are accurate to 1/8000 of a revolution. Several hundred times the necessary control for this application. Although it is useful for programming complicated maneuvers, and for making fine adjustments to course and attitude.
#110
| When you say stall from not enough load, I take that to mean that a smaller prop would be more loaded and therfor less prone to stall? But would require more power to opperate at cruise speed?
#111
Any blades stall if they are spun too fast with respect to the oncoming flow. If you rip from ahead to astern the blades will be in a stall condition with a high angle of attack because the flow is initially in the wrong direction. They are not as effective as operating with attached flow. A smaller prop will stall more readily because it has heavier loading. Rick W |
#112
All "normal" marine propellers have higher drag locked than free running at any rpm. Stopping the propeller will cause a drag of about 0.5*rho*Cd*Ap*V^2, where Ap is the projected blade area and Cd is ~1 (depends mainly on P/D). So at 8 kn a 12" 30% projected area prop will have drag of about 200 N, but that will drop to 50 N at 4 kn and then you can certainly get more by spinning the propeller backwards. If you have several of these (2, 3 or even 4???), you have a very good brake by just locking them, but this brake looses its power at low speeds and you need to spin them backwards. Here are some measurements and theory: http://strathprints.strath.ac.uk/567...ints005670.pdf |
#113
The prop I based the calculations on has a BAR of 12% and projected area somewhat less. So even with a 250W regen limit it will still be better than the stopped drag. Rick W |
#114
| I'm so confused. It changes prop design according to watts used. It seems like you should input a need and it would tell you the required power.
#115
#116
| Sorry Rick, JavaProp. I have been thinking that the idea is to try different wattages untill you get similar props for different speeds.
#117
| When you use the "Design" function Javaprop notionally gives the best prop based on the set design conditions and the chosen blade profile. The sequence is to go to the Options page and set parameters for water(density 1025, viscosity 0.0000013), the next is to go to the Airfoils page and select foils and their AoA for what you want to do. For your case start with the E193 100,000 Re# at 1 degree angle of attack. Go to the Design page and set the prop diameter, number of blades, rpm, hub diameter and the design speed with the corresponding hull drag. You then press Design It. This will be close to the best prop for you design conditions. If you want to see what the conditions are at a different speed you need to adjust the rpm on the design page and go to the Multi-Analysis page to see how it performs. As a first approximation if you want to see the power for half speed, halve the rpm (DO NOT PRESS DESIGN IT), go to the Multi-analysis page and Analyse. You need to scan down the table until you find half the design speed and check that the drag is 1/4 of what is was at the design condition. If it isn't repeat the process making small changes to the rpm. I have a more functional Excel based model that does all this automatically and allows for all the variations in parameters and endless variety of foil sections but it reflects a few years of unpaid development that I do not want to give away. If you do a few screen dumps of what you have set up I can advise if you are on the right track. You need to arrive at a blade that is robust enough to take the forces. No good designing blades that have a chord of 10mm for example. You should not go under 25mm chord at the root for the sort of thrust you need to design for. Rick W |
#118
| Thanks Rick, I have a few pieces of unpaid software as well. I actually did changes the options, but I was changing the speed and RPMs and of course it was not working without substantially reducing wattage, kind of a trial and error thing. I'll try using the multi page
#119
How did you determine the overall shape, at the edges, from the hub to the tip? It looks like the cord ratios are constant from the hub to the tip. Is that true? If true, what was the reason? On the Java Prop site he list foils with large ratios for use close to the hub. He mentioned more efficient at the higher attack angles, I can see that, also the “thicker” blade towards the hub would be stronger. Sorry, I expected the image to follow the quote, it was a picture of the aluminum prop you showed earlier in this thread.
#120
Rick W |
| Defining required engine power and gearbox ratio | marineengineer | Props | 12 | 12-13-2009 05:56 AM |
| Power Foils-added power to carry sail... | Doug Lord | Sailboats | 33 | 08-18-2009 09:35 PM |
| Power/Resistance Calculation for Planing V-Hull & Fuel/Engine Required | Kapitan_Raider | Outboards | 24 | 11-26-2008 04:34 AM |
| How do you calculate the power required for propulsion? | slipshot | Propulsion | 3 | 08-19-2008 08:28 AM |
| How much power is required? | bxbbuddy | Outboards | 1 | 12-19-2007 01:50 AM |
