Go Back   Boat Design Forums > Design > Propulsion > Props
Old 06-22-2011, 09:01 PM
kayant1 kayant1 is offline
Rep: 10 Posts: 14
please somebody help - what prop for amerosport 230 with 350 alpha
i have a 1988 amerosport 230 and i put in a new 350 (5.7) with an alpha 1 drive this is a 23 ft boat that 6,000 pounds its got around 260 to 270 hp i need to know what size prop, the boat didn't come with one can anyone tell me what i should use thanks
Old 06-24-2011, 08:11 PM
Rep: 10 Posts: 14
help me please, anybody!!!!
anybody know what size prop came with a 1988 amerosport 230 my boat didn't come with one going through hell trying to find the right size can anybody help please
Old 06-24-2011, 08:12 PM
Rep: 10 Posts: 14
the prop you need is
Old 06-24-2011, 08:31 PM
IMP-ish IMP-ish is offline
powerboater
Rep: 68 Posts: 238
Go to the largest marina near you and ask to try a few props if you buy a prop from them. You need a baseline. Then you can dial it in.
For example if you start with a 14 1/4 x 17 see what the WOT (wide open throttle rpm) is compared with the recommended engine WOT on the engine cover sticker (don't exceed the recommended WOT) Every 2" of pitch reduction equals around 300 rpm increase.
Old 06-24-2011, 08:33 PM
powerboater
Rep: 68 Posts: 238
Or do a google search and find a few amerosport 230s for sale with the same engine and ask what prop. Most owners are happy to help a fellow owner.
Old 06-24-2011, 08:35 PM
powerboater
Rep: 68 Posts: 238
Or give this a spin.
http://www.watercraftservices.com/Propwiz.php
You will still do best by trying a few props at a local marina to dial in not only wot but also the characteristics you need. Your boat may have picked up more weight than you expect. How easy does it plane? Do you want more top end or hole shot? Do you want more bow lift or less. Etc.
Old 03-29-2012, 10:17 PM
Rep: 10 Posts: 14
the prop size is a ss mirage plus 15-1/2" 18 to 19 pitch
Unread 05-25-2012, 10:38 PM
Rep: 10 Posts: 14
well i found the best prop for that boat it a mirage plus 15"-with a 18 pitch if anyone needs to know
Older 305 to Newer 350 swap, Mercruiser Alpha Gen I duke Sterndrives 5 01-07-2011 05:17 PM
Schemetic 1990,Sea-Ray 230 tenn.vol. OnBoard Electronics & Controls 0 06-23-2009 05:05 PM
Alpha One No Go! chaparral2130 Sterndrives 2 07-02-2007 08:32 PM
help.alpha 1 saabster Sterndrives 2 04-27-2007 11:19 AM
Chris Craft Amerosport JCO Powerboats 1 11-02-2004 12:48 AM
