Go Back   Boat Design Forums > Design > Propulsion > Props
Old 09-11-2010, 09:19 AM
KeiJei KeiJei is offline
Rep: 10 Posts: 5
Pedal Powered Prop Design [?]
Hi guys, I have very little knowledge on prop design and I have a school project, which is to make a pedal powered water raft.
I plan to fabricate my own prop if I wont be able to find a commercially available one.
Can you guys give me an idea on what good prop to use?
- 400 kilograms of weight (consisting of 3 people + the bike + others)
- Doesn't need to move in a "fast" pace, just as long as it will move, its fine.
- Gear ratio from pedal to propeller shaft is about 7-8.
Old 11-13-2010, 02:22 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
Look up Rick Willoughby's (he's off the board at the moment, but is probably the pro on these things) threads, Pedal Powered Boats for example. His posts are under the name Guest625101138.
His thread listing
I think he's written a tutorial on building a prop also, just don't remember where.
Here's how I made my composite propeller Building a small trolling boat #93
Hope this helps
Lurvio
Hopefully creating something useful, since 1983.
Old 12-04-2010, 05:08 PM
kbowen kbowen is offline
Rep: 25 Posts: 19
I have heard that some folks use glass-filled polycarbonate model-airplane propellers in pedal boats I have experimented with these in trying to get more speed out of a trolling motor. More speed, yes, but not necessarily more efficient: The ampere draw (therefore: resistance to rotation) can be high. I think the big drawback is that near the hub, an airplane propeller can be quite chunky, but a boat propeller probably needs to be more svelte. But if you are experimenting, there are a lot of different diameters and pitches of strong model airplane propellers "on the shelf" and pretty cheap. Caveat: not at all "weed free"
Old 12-04-2010, 09:55 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Large, two bladed airplane props work great but each pedaler is only going to produce about 100 - 150 watts (0.15 - 0.20 Hp) so if only one pedals (one bike) with all that weight, you're going to be hard pressed to make any headway at all if there is any current or wind against you OR simply too much drag from poor hull design.
I do believe you're going to have to get everybody on board pedalling.
-Tom
Pedal Powered Boats Guest625101138 Boat Design 1580 05-23-2012 11:39 PM
Propellor for pedal powered catamaran Tiny Turnip Props 15 02-05-2012 06:27 PM
Where to start on a pedal powered boat? ryan808 Boat Design 67 06-09-2011 06:09 PM
Pedal Powered Boat for the Baltic Sea / Coastline KalleA Boat Design 53 05-30-2009 11:09 PM
pedal powered wave piercing thing Boston Boat Design 0 05-13-2009 12:23 AM
