| Packing new stuffing box I have re-powered my Stone Horse with a Beta 14. New 3/4" shaft with Buck Algonquin spud type stuffing box. Specified packing for that arrangement is 3/8". I've decided to try Gore GFO packing this time. Only two rings of packing comfortably fit inside spud (gland). Most recommendations advise three. But there really isn't space enough. What do folks think? Are two rings sufficient, inasmuch as the space for packing material is essentially filled using two? I appreciate all thoughts here. Thank you. Robert |
| No worries, often different packings do not fit the area allocated, just put the seams at 10 and 2 o'clock.
| If you have only space for 2 rings then you have little alternative. I would fit them staggered as suggested and use grease. |
| ...another thing to note, let the job leak at first, tighten as it beds in, this will allow the stuffing to be cooled and not just burnt up. It may take an hour of running to get it right, but it will last a lot longer if done right from the start........certainly remove all of the old stuff. You can wrap the new packing around the shaft and then cut through the rolls to get the right sized rings, cut at 90deg for square ends, and they will fit perfectly.
| "I would fit them staggered as suggested and use grease." 'let the job leak at first, tighten as it beds in, this will allow the stuffing to be cooled and not just burnt up." With Goretex or similar neither of these techniques are desirable, tho staggering the rings is required.. Stick it in , go for a slow ride and tighten just till NO DRIPS!!, and you are done. That's why you paid all that extra for 21st century packing. FF |
| "With Goretex or similar neither of these techniques are desirable"....funny you say that, I was sure when I had a meeting with Mr Gore in Sydney years ago, we were discussing this. so I went to their web site, please read the last paragraph of this pdf, it specifically says exactly what I said, let it leak...... http://www.gore.com/MungoBlobs/123/4...structions.pdf
| it specifically says exactly what I said, let it leak...... So it does! Will check the other brand and see if constant leaking is required. FF |
| I would not say it was required but tolerated, stuffing greasy string into a shaft has been the only way for 100 years. If it is not tight and does not leak I would say it was ok. A grease nipple behind it will ensure a water tight seal when lay up. |
| Stuffing Box re-pack break in? | 7228sedan | Inboards | 5 | 06-14-2011 07:05 AM |
| Stuffing Box Packing Replacement | DSCMEARL | Inboards | 7 | 11-21-2010 09:53 AM |
| Stuffing box | wudenbote | Inboards | 5 | 05-20-2009 12:24 PM |
| stuffing box question | mmd | Propulsion | 3 | 10-25-2007 10:31 PM |
| alternative to stuffing box? | need-help | Boat Design | 2 | 03-23-2006 09:34 AM |
