Go Back   Boat Design Forums > Design > Propulsion > Props
Old 05-14-2010, 04:46 AM
stalin stalin is offline
Rep: 10 Posts: 12
Open Water Efficiency
I have optimised the propeller as follows:
Propeller Diameter = 1.1
P/D = 0.75
Pitch = 0.8250
AE/A0 = 1.0328
RPM = 689.43
open water eff = 0.42
cav.number = 0.2857
Vessel particulars:
LWL = 21 M
dISP = 117T
Engine is 1x400 hp @1800 rpm, with gear ratio 2.59. Max diameter of the propeller is 1.1m, according the stern shape. Can anybody confirm that the open water efficiency is reasonable for this size of vessel.
Thanks in advance.
Old 05-23-2010, 03:31 PM
bmsyachts bmsyachts is offline
naval architect
Rep: 10 Posts: 7
Hi Stalin,
What is the design speed of the boat at which the prop is to be selected?
Old 05-23-2010, 10:05 PM
conceptia's Avatar
conceptia conceptia is offline
Naval Architect
Rep: 97 Posts: 193
also the number of blades...
Cheers
Aswin
"Aim of any argument or discussion must not be victory, but progress."
Old 05-28-2010, 06:54 AM
Rep: 10 Posts: 12
Sorry for late reply. No.of Blades are 4 & design speed of the vessel is 10 knots.
Old 05-28-2010, 07:14 AM
conceptia's Avatar
Naval Architect
Rep: 97 Posts: 193
hey stalin, the effieciency value is ok. But you can improve it if you want to. I feel the main problem is the space constraint for accomodating propeller, right? In that case, you can ahead wid dis. But also listen what Daiquiri, Leo and others has to say about it.
Cheers
Aswin
Old 05-28-2010, 03:41 PM
bit bit is online now
Student
Rep: 34 Posts: 15
Pitch too high?
D = 1100 mm
P = 711 mm
Ae / Ao = 0.7
z = 4
w = 0.1344
Eta0 = 0.466
T = 31.11 kN
Pe = 195.7 hp
Pb = 415.3 hp
No. Cav. = 0.271
Cavit. = 4.91%
My opinion ...
Old 05-29-2010, 10:51 AM
naval architect
Rep: 10 Posts: 7
Open water efficiency
Your selection is most likely correct, but in terms of efficiency not close to "optimized".
The potential open water efficiency could be as high as 76% but with a much lower prop RPM and much larger diameter (in fact, huge!) Twin screws ease the situation but still very slow RPM and large diameter props to enjoy full potential prop efficiency.
So it's a balancing act with compromises in efficiency (fuel consumption) fighting prop size and space constraints and first cost.
Old 05-29-2010, 06:04 PM
Student
Rep: 34 Posts: 15
Ok.
Is D = 1100mm : stop.
Better not be
Bye
Water logged 23' Tsunami open fish Capt Mac Boat Design 18 01-25-2011 07:48 PM
Plans for open water rowing shell sander Boat Design 2 02-21-2010 03:13 PM
salt water vs fresh water bouyancy in boat plans blackdaisies Boat Design 8 04-30-2009 08:00 PM
Twin-Propeller Open Water Efficiency EviLCuLT25 Propulsion 0 04-12-2009 04:52 AM
Diesel Efficiency vs. Gas Efficiency Northwester Diesel Engines 23 02-14-2009 03:49 PM
