Go Back   Boat Design Forums > Design > Propulsion > Props
Old 06-22-2011, 10:21 AM
save save is offline
Rep: 10 Posts: 4
naval architecture exercise
Hi!!
I'm searching for some exercises related to screw design..
I'm talking about Wgeningen B series, screw strength with Taylor, cavitation analysis with Burrill..
I have theorical dubts related to these problems, so I would like to see some correct examples..
Anyone could help me?
Thanks a lot!!
Old 06-22-2011, 11:20 AM
Rep: 1758 Posts: 1,561
No one looks into propeller design as an exercise; there are too many variables in it to make a good basic learning experience.
What is the problem you are having: theory or application? And approaching the propeller design from what perspective: initial design? FWIW, the three things you named are only tenuously related. Wageningen B design is based on a standard series data (1948) look up chart, Taylor blade beam analysis (1910) doesn't apply to standard series, the same with Burrill's cavitation (1943) and stressing (1959). I suggest that you go read Chapter 6 of Resistance and Propulsion of Ships (SV. AA. Harvald, Wiley & Sons, 1983, ISBN 0-471-06353-3) with particular attention to 6.6 Cavitation and 6.7 Propeller Design Theories.
Old 06-22-2011, 04:23 PM
Adler's Avatar
Adler Adler is offline
Rep: 110 Posts: 98
Suggestion
See also that if you can follow the maths' level that applied.
"Marine Propellers and Propulsion" J S Carlton Senior Principal Surveyor
Technical Investigation ,Propulsion
and Environmental Engineering Department of Lloyd's Register
First Published 1994
Butterworth and Heinemann Ltd
Linacre House , Jordan Hill , OXFORD OX2 8DP
ISBN 0 7506 11 43 X
British Library Cataloguing in Publication Data.
Old 06-23-2011, 05:26 AM
Rep: 10 Posts: 4
Thanks.. This is my first problem:
Given:
- L,B,T,displacement,Cx, S
- effective power curve for different ship velocities
- shaft horsepower
- shaft efficiency
- wake fraction w
- thrust deduction fraction t
- relative rotative efficiency
Choose:
Best 4 blade propeller from B series chart that give the maximum service velocity
Old 06-23-2011, 06:24 AM
Rep: 10 Posts: 4
i also know the RPM
Old 06-23-2011, 07:16 AM
Adler's Avatar
Rep: 110 Posts: 98
Regarding your notes....
Please see the attached files.
Prof. Sverre Steen NTNU had developed a .xls file for Propellers Calculations (90136.xls) and a .doc file for instructions (90137.doc).
I think that is near of what you asked .....
If you need to try on this .xls file you have to contact him at:
http://folk.ntnu.no/sverres/
Old 06-24-2011, 11:04 AM
Rep: 10 Posts: 4
is not what i was searching for but thanks a lot
Old 06-24-2011, 12:56 PM
Given:
- shaft horsepower
- shaft efficiency
- wake fraction w
Choose:
i also know the RPM
You specificaly need to read Principles of Naval Architecture (1988 ed), Volume II, Chapter 6, Section 8.3 (pgs 186-204) as this appears to be a problem lifted straight from the text.
Old 07-03-2011, 07:51 AM
conceptia's Avatar
conceptia conceptia is offline
Naval Architect
Rep: 97 Posts: 193
yes.. PNA Volume 2 will serve the cause.
Cheers
Aswin
"Aim of any argument or discussion must not be victory, but progress."
Old 07-20-2011, 03:30 AM
kerrett kerrett is offline
Rep: 10 Posts: 5
hi save I send you something via mail..
Old 07-20-2011, 03:32 AM
Rep: 10 Posts: 5
Are you studying in Italy?
Naval Architecture In Japan? Pochi Education 8 02-04-2011 01:56 AM
New Naval Architecture Course in Australia Leo Lazauskas Education 2 07-30-2010 08:11 AM
College for Naval Architecture Archive Education 15 04-07-2008 12:42 PM
Naval architecture education A|ex Education 6 12-12-2007 10:59 AM
Naval 'Architecture' willace Metal Boat Building 5 01-05-2005 08:23 AM
