| Help..Propeller Moment Of Inertia Calculation Now i am calculating for design propeller kaplan type, but i can't determine/calculate moment inertia of propeller,on air condition and in the water condition. anybody can help me? thank you... |
| Let me refer you to a paper by our staff: MacPherson, D.M., Puleo, V.R, and Packard, M.B., "Estimation of Entrained Water Added Mass Properties for Vibration Analysis", SNAME New England Section, Jun 2007 You can find it on our Knowledge Library page: www.hydrocompinc.com/knowledge/library.htm In this paper, you will find some calculation techniques and parametric prediction methods for the moments of inertia. Unfortunately, most of the parametric methods were for open propellers (that, of course, have a different blade profile than a Kaplan propeller), so these will probably not be useful. However, an approach is described for a "blade element" calculation that would be suitable. It requires radial definition of some of the geometry, so you'll have some work to do, but it is an appropriate technique. (This is the approach that we use in our commercial PropCad propeller modeling tool.) Don MacPherson HydroComp |
| Thanks so much for the reference, we have try to calculated with Burril Estimates formula (base on your article), the result has 3517.76 kg.m^2. I think this value are too high. We have two comparison data for the Moment of inertia in the water and on the air as follows : > Prop Diameter 2.4m Wk^2 in air = 295 Wk^2 in water = 351 > Prop Diameter 2.2m Wk^2 in air = 212 Wk^2 in water = 307 Maybe you have another formula for Moment of Inertia on Air. Sam Antony MCCI |
| I have reviewed the original paper, and find a publication error. The Diameter in the Burrill simple estimate of IE should be in feet, not inches. The output is LBM-FT^2. (This would be corroborated in the Appendix examples.) Also remember that this is for the supplemental inertia of the water (not the mass+water), and is for open propellers, not ducted porpellers of the Kaplan style (as described previously). Don MacPherson HydroComp, Inc. |
| OK, thank you very much... nice to discuss with you Sam Antony MCCI |
| moment of inertia | abhishek | Boat Design | 10 | 10-03-2009 07:28 AM |
| Mass Moment of Inertia | netjaws | Boat Design | 13 | 03-25-2009 12:06 PM |
| Moment of inertia | ghisio | Sailboats | 3 | 10-30-2007 09:29 PM |
| Mast Moment of Inertia | JCD | Boat Design | 0 | 09-30-2007 06:42 PM |
| moment of inertia | dionysis | Boat Design | 6 | 09-08-2003 08:09 PM |
