| Defining required engine power and gearbox ratio Is there any practical way or a formulation to calculate required horse power and defining gearbox ratio for sailing boats and power boats? Can anyone help me about this, Thanks |
| First step is to measure, calculate or approximate the drag on the hull at the target speed. You then need to determine the largest diameter prop you can fit. There will be factors such as clearance to the hull and shaft angle that dictate this. Ideally the shaft angle is horizontal but angles as high as 15 degrees are tolerable depending on the prop. Having the target speed, diameter and the boat drag allows you to determine the best pitch, shaft speed and gear ratio. There are various ways to do this. Rick W |
| Rick , thank you so much. Is there any document that shows the calculation method for all these terms? |
If you want to start by an example rather than buying books or googling for a long while then- To start with drag - what type of hull are you considering, length, beam and speed? There is no single method that suits all applications. Rick W |
| I need to collect for sail and power boat. |
E.g. I have a Yanmar 1GM10C with 2.64:1 saildrive and a 14x8 folding propeller. It likely has an efficiency of ~50% at full speed of 6.4 kn, 3480 rpm (1320 rpm at shaft). I could get a much better efficiency: 18x18 propeller at 640 shaft rpm would give over 60% 30x40 propeller at 250 shaft rpm would give over 70 % 40x56 propeller at 150 shaft rpm would give almost 80% But what could I do with shaft rpm of 1300 rpm? Not much better considering also cavitation limits. |
| Joakim You make the point well that efficiency is strongly related to diameter. We had not settled on the gearing. If the gearing is given then the prop selection will most likely be set by the gearing rather than what can be fitted. Rick W |
| Big props= big hubs big hubs = big shafts. Are you suggesting that if he is building a 40 foot sail boat and he "could" fit a 4 foot diam prop he should do so? |
Is it worth making a non-standard 5:1 gear and buying a much more expensive 18" propeller to get a bit better efficiency? How important is the difference between 50% and 60% for a sailboat. |
| The question was about existing boats. The diameter of the prop is inevitably constrained so you go for the biggest diameter that will fit. This is a starting point. We are not modifying the hull or starting a new design. You cannot buy really efficient props for pleasure boats you have to make them so this is beyond the question posed. Unless the hull is specifically designed for a large diameter prop there will be constraints on the diameter imposed by the hull. Some hulls with tunnels will actually fit a decent diameter prop otherwise the hull and shaft angle constrain the prop diameter to something less than you would otherwise choose if you could fit it. On higher speed boats you get to the point where the strut or leg drag becomes a consideration. As speed goes then cavitation becomes a consideration as well. Rick W |
| best power/weight ratio 700hp Diesel | Munchies | Diesel Engines | 1 | 10-17-2009 07:04 PM |
| Defining a motorsailor | gonzo | Motorsailers | 17 | 07-10-2009 02:05 PM |
| Power/Resistance Calculation for Planing V-Hull & Fuel/Engine Required | Kapitan_Raider | Outboards | 24 | 11-26-2008 04:34 AM |
| How do you calculate the power required for propulsion? | slipshot | Propulsion | 3 | 08-19-2008 08:28 AM |
| How much power is required? | bxbbuddy | Outboards | 1 | 12-19-2007 01:50 AM |
