Go Back   Boat Design Forums > Design > Propulsion > Props
Old 03-09-2006, 12:28 PM
stephanabradley stephanabradley is offline
Boat Builder
Rep: 10 Posts: 9
Can't find a prop?
Hello all,
I am progressing on a prototype, but can't seem to find a prop.
The boat is a very small cedar strip runabout, like the ones you would see in the 20's and 30's, but smaller. It will have inboard power and a Kitchen rudder to minimize mechanical weight.
The prop size should be an 8 x 6 three blade according to calculations, but I can't seem to find anyone that makes small props like this any more. I need the prop, all parts to connect to the shaft, and a 36" shaft if I can find it.
Any thoughts or leads are appreciated.
Thanks,
Stephan
Bradley Boatworks
www.bradleyboatworks.com
Old 03-10-2006, 03:52 AM
propellerman propellerman is offline
erispropellers
Rep: 10 Posts: 10
Eris Propellers
Dear Stephan,
I will try to help you ,we are a propeller foundry in Turkey .And sometimes build this kind of propellers for model vessels .
See : www.erispropellers.com
SENER ERIS
Old 03-10-2006, 06:52 AM
Rep: 700 Posts: 3,207
Look in the outboard shops , what you want is probably made for 4 hp or so.
You will need a clapped out outboard drive shaft (to fit the prop) and need to weld it to the shaft of your stuffing boxes choice.
FAST FRED
Old 03-10-2006, 10:47 PM
fredrosse fredrosse is offline
USACE Steam
Rep: 25 Posts: 46
I have bought several of this size prop, three blade brass, made by Michigan, 8 x 7, 8 x 8, and a 6 x 6, on e-bay, usually less than 20 USD.
Find A Slip Levi Open Discussion: All Things Boats & Boating 0 02-01-2006 11:04 AM
find the builder 1960vw Fiberglass and Composite Boat Building 0 09-25-2005 08:43 PM
need to find info Jeff Walkowiak Boat Design 2 02-12-2005 12:38 PM
Can you help me find my designer? Harrible Boat Design 2 06-27-2004 11:11 AM
Help me find a design... guest Boat Design 2 03-11-2004 04:35 AM
